07-17-2013, 09:54 PM | #1 |
67 72 control arms
Does anyone know if 73-87 lower control arms can be pair with 67-72 upper control arms? I know about the differences in ball joints just want to know if it can be done.
07-17-2013, 10:13 PM | #2 |
67-72 parts collector,…
Re: 67 72 control arms
Yes.
I assume this is on a 1/2-ton truck?
07-17-2013, 10:18 PM | #3 |
Yes it is a half ton. I put 3 in Belltech drop spindles on my 70 c10 and had to due some trimming to clear the LCA. Long story short I think I took much material off because I had it on jack stands. For peace of mind I just want to replace them.
07-17-2013, 10:38 PM | #4 |
I think the only difference is the bushing type. I believe everything else is the same.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
07-17-2013, 10:40 PM | #5 |
Use the correct balljoint for your spindle,... and any c10 lower 73-87 a-arm will be fine.
