Old 07-18-2013, 12:52 PM   #1
74sqrbdy
74sqrbdy's Avatar
Late model steering column swap
I have a 1974 c10 with a non tilt column. Does anyone know what it takes to put in a later model tilt column that has the headlight dimmer switch in the turn signal. I was wondering if the ignition switch plug and other plugs were the same. I dont need to use the dimmer switch on the column because I can still use the floor mounted one. I have been looking for a nice early tilt column at my salvage yards but they are always trashed. I found a nice later model one today but not sure what it takes to make it work. Thanks everyone.
74sqrbdy is offline   Reply With Quote
Old 07-18-2013, 02:34 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Late model steering column swap
I'm curious as well as I may do this to mine. Being a Manuel you alredy have enough to do anyway with hands and feet haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-19-2013, 04:38 AM   #3
wraprail
wraprail's Avatar
The 74 is a 1"x48 spline while the later column is 1"DD? You may be able to use the steering shaft from the later column but then it won't fit your early steering box
wraprail is offline   Reply With Quote
Old 07-19-2013, 07:28 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
don't know about the 74, but IIRC I pulled the (dimmer)wires outa the plastic plug should slide in the needed plug
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-19-2013, 11:41 AM   #5
1774btcrew
1774btcrew's Avatar
I would sell the later model column and buy the correct one. They both go for the same price right around $150. The later columns look big and bulky in the earlier trucks. I have rebuilt a lot of these columns and the earlier ones are also easier to work on as they have less parts. I also like the the early columns have the metal upper collars
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 07-19-2013, 12:28 PM   #6
74sqrbdy
74sqrbdy's Avatar
Thanks for the replies....I agree 1774btcrew, I too like the slimness of the early column, and the plug and play part of it is nice. I will just have keep looking for a decent one.
Old 07-19-2013, 01:59 PM   #7
1774btcrew
1774btcrew's Avatar
You are in California. It will be easy. There are a ton of those trucks there at the yards. The only tilts that are hard to find are floor shift ones. Get in contact with me if you want and I can suggest a couple good U Pull Its there.
Old 07-19-2013, 02:03 PM   #8
Ziegelsteinfaust
Try pick a part in Ontario off of Milliken.
I got mine from there, and I usually see a early tilt every time I go.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-19-2013, 05:12 PM   #9
74sqrbdy
74sqrbdy's Avatar
Thanks 1774btcrew. I have two pick-a-parts and a Ecology near me and I have probably made 10 to 15 trips to them in the past 6 months. The early tilts always seem to have bad bearings or the gear shifters have been forced so they could take it out of gear without a key. I also found one that the steering wheel lock had been forced so they could steer without a key. I think your right....I just have to keep looking.
Old 07-19-2013, 08:02 PM   #10
1774btcrew
1774btcrew's Avatar
Send me a pm. I have a suggestion for you
