Old 07-18-2013, 03:45 PM   #1
72C20Highlander
72C20Highlander's Avatar
Quadrajet Replace or Rebuild
I've got 72 C20 with 402. Only 59,000 miles but such little us over the past 10 years carb seems to be maybe gunked up. Won't idle very smooth, runs down the highway fine though. Truck is super straight and clean, Orig. except tires, exhaust,shocks, spark plugs and wires. Should I rebuild Orig. card or is there a much better performing replacement I should use that will accept factory air cleaner etc.
1972 Custom Deluxe 20 Highlander Pkg, 402, TH400, Factory AC, Original Survivor.
1969 Custom Camper/20, 350, TH400, Wood Bed, Survivor.
72C20Highlander is offline   Reply With Quote
Old 07-18-2013, 04:09 PM   #2
72 Sierra
Re: Quadrajet Replace or Rebuild
I would rebuild keep it original..just my 2 cents
72 Sierra is offline   Reply With Quote
Old 07-18-2013, 04:19 PM   #3
truckster
truckster's Avatar
There's not a better performing replacement. I'd rebuild it. Cliff Ruggles is a really nice guy and sells premium kits at reasonable prices. His book has just about everything you'd want to know about Quadrajets in it:
http://www.cliffshighperformance.com/
truckster is online now   Reply With Quote
Old 07-18-2013, 04:32 PM   #4
72C20Highlander
Yes, rebuild is the response I thought I would get and staying original I thought just made the most sense. Guess I'll just have to buy another truck that is a project and build a power plant for it. Thanks for the tip on where to get a rebuilld kit from.
Old 07-18-2013, 04:49 PM   #5
GRX
GRX's Avatar
The Q-jet is a great carb yet also complex. So building one is not for beginners.
Cliff's book on the link above is an excellent resource for info.
>> http://www.cliffshighperformance.com/buy_book_2.html
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-18-2013, 05:59 PM   #6
Eddie H.
Eddie H.'s Avatar
As long as the carb is original and hasn't been monkeyed with by someone who don't know what they're doing, I would say rebuild it. They are great carburetors.
I have also seen a number of quadrajets that were damaged beyond repair by shade tree mechanics who thought they knew how to rebuild one.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-18-2013, 09:13 PM   #7
geezer#99
geezer#99's Avatar
I vote keep it and rebuild.
And I've seen professional mechanics who thought they knew how to rebuil one.
A link for you. Pay close attention to hooking the needle on the float section.
http://www.crankshaftcoalition.com/w...#Trouble_spots
geezer#99 is online now   Reply With Quote
Old 07-19-2013, 12:27 AM   #8
72C20Highlander
I ordered the parts from Cliffs High performance today. Will have my local Mech. who's got plenty of old school skills to rebuild it. Thanks for the input
Old 07-19-2013, 12:53 AM   #9
Rufton
Even though I prefer Eddy, I'd rebuild the Q if it's OEM to truck.
I trading OEM carb as core when I bought reman carb at parts store years back; twas mistake.
Rufton is offline   Reply With Quote
Old 07-19-2013, 09:43 AM   #10
JMac11
JMac11's Avatar
I am mechanically inclined as one would say, rebuilding the QJet is easy with Ruggles book. Take your time, follow the directions, avoid interruptions and it is cake...... Night and Day difference and I knew that the throttle shaft needed rebushed, but did not do it because I lacked the confidence that the rebuild would work.... Runs to good to take it back off....
JMac11 is offline   Reply With Quote
