07-18-2013, 06:12 PM | #1 |
Dumb question about timing
Trying to set timing on an 82 c10 with a 350. When I advance my timing my truck idles better but the idle goes up. At this point I know I am supposed to take it down with the idle control on the carb (holley) but it doesn't change. Any ideas? Also got a wicked backfire only when I turn the truck off.
07-18-2013, 06:15 PM | #2 |
Re: Dumb question about timing
Also any idea why the truck would idle high but well in park and then fall on its face and die when put in gear?
07-18-2013, 08:50 PM | #3 | |
07-18-2013, 09:30 PM | #4 |
Yes vacuum advance is plugged. It is a brand new msd dist and a new holley carb.
07-18-2013, 10:07 PM | #5 |
78K & 79C Jimmys
choke? is it setup working?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-18-2013, 10:09 PM | #6 |
recheck the wires make sure the are in order , get a timing gun if you hv not already , your timing is either to low or to high. I cant remember if its backfiring thru carb, or thru exhaust , 1 of these is an indicator of low timing and 1 is an indicator of high timing
07-19-2013, 12:27 AM | #7 |
Which holley carb?
The secondaries can be adjusted to slow down your idle. It backfires due to lack of timing. It dies when you put it in gear due to lack of timing. |
