![]() Join Date: Oct 2006
getting the ball rolling..... again
Well after a long time I am finally getting my rear end in my 60 swapped out !
A few years back I rounded up a rear end off of a 67 and stashed it away. I also got an adjustable track bar, lowering springs with hardware, u joint, new axle saddles and u bolts. I was going thru a ruff patch ( as we all have) and put the truck on the back burner. Easy to do as it was drivable. I hope to have it back Monday, then I will do the drop spindle disc brake swap.( that I have also had for a while) The rear end has 5 lug axles so I am not sure what wheels to run, I have some stealies ,older 15" Cragar S/S , Some 15X8 newer style rallies ,100 spoke wires, and some 15 x8 Supremes. I'm leaning towards the Supremes but don't want to run a 235/75r15 white wall. Any suggestions? Stay tune as I up date this post
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Re: getting the ball rolling..... again
Hey Sal, got pics of the Supremes? Never seen any so I don't know what they look like
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
here you go.....
+1 on the Supremes. I've seen em before but didn't know the name. Those are the sheezneezy!
64-66 CHEVY JUNKIE
Man Sal ima lean towards the 15-8 Rallies... Are they the 80's Style Rallies?
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
yup there 80's style
Hey Sal the Steelies or Supremes got my vote... What direction you gonna do the Steelies? Color, bullets, center caps, rings or white walls..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Those will look sharp on there...cant wait to see some more pics
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
this is what I am running right now, The 5 lug stealies I have are painted a light blue.
and these are in my garage
![]() Join Date: Sep 2009
Supremes with narrow whitewalls
Thanks for the suggestions... I think I'll just try them all on and decide.
Ok so here is an update: I dropped the truck off with all the parts all except the keys !!! To make maters worse I went out of town and was unable to drop the keys off till today. So I went from front of the line to stand by! On the plus side I picked up a spilt manifold for it. I have long tube headers on it ( its a 250 6) and they hang REAL low, limiting how low I can drop the front end . I couldn't find a cheap set of shorty headers so the split manifold will have to do. Hope to have a better update soon.
Chevy addict
Cragar S/S be different
#13 |
Almost done except for the trac bar. Looks like the bolt on trac bar I got from CPP needs to be tweaked. It's too long so we will cut it down tomorrow and call it good.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 07-23-2013 at 08:26 PM. |
#14 | |
Never Ending Projects
Just giving some info so you don't modify something and find out you didn't need to.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 | |
#16 |
Update the rear end is in !!! But.............. I couldn't get the rear brakes to bleed. So wheel cylinders, shoes, drums and hardware will be replaced tomorrow. stay tuned..................
#17 |
Update: well looks like my master cylinder is bad. Guess I got do the disc brake swap sooner then latter. The rear end swap came out great, and drives sweet! But since the rear end was a bit wider I ran into a problem.
As I had posted I was debating on what rims to use.... well that changed. Keep in mind my truck is a 1960 fleet side long bed. The 15x8 Supremes, the 15x8 Cragar S/S ,and the 15x8 80's Rallys are all to wide. So that narrows it down. I am going to go with the stealies painted red with some Spider caps.But will run my moon caps till I swap out the front drums. I also had to replace my starter today ,and looks like my Ignition switch decided to sleep with the fishes too.. ah the fun of owning an old truck. And before I get flamed Pictures are on the way.
#18 |
Hollister, CA.
![]() Join Date: Sep 2006
I was waiting patiently for the "Im ready for the rear-end swap call", but looks like you got it done ...
Awesome !
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#19 |
SIR
i ran into the same problem on my rear end change...had to cut 1" out of the fender lip to make room....
66long low fleet http://community.webshots.com/user/LVNR66 |
#20 | |
![]() Sir were have you been ? hope all is well for you. Thanks for the tip. As it is the 15X8 Supremes hit with no tire on them.
#21 |
Replaced the ignition switch. I found my receipt for my master cylinder and got it replaced under warranty, bench bleed it had the wife help bleed the brakes and took her to dinner for her help. The truck runs great and stops just as good.
I was going to do my disc brakes but I didn't have the outer tie rods so I ordered them up from LMC. Replacing my old master cylinder was easy and besides the time the only cost was a quart of brake fluid.
#22 |
Hey Sal!! How's it hangin'!!
I liked the color of your truck so much I bought one like it. A few years newer though! His name's 'Chuck'! |
#23 |
Nice looking rig
#24 |
here are some pics
#25 |
Just a corection the rearend came out of a 1970 C10 not a 1967 still 3.73
