Old 07-18-2013, 09:58 PM   #1
bryan76
vacuum hose for vents and defroster
i got a non ac cab but done cut the firewall for this have all the stuff from a burb for under dash etc all i want is the heat and vents and defroster to work all the lines are hooked up to actuators the main source from engine the line was melted can i just hook up to a vacuum source from intake to the source line then to ac controller thanks
bryan76 is offline   Reply With Quote
Old 07-18-2013, 11:32 PM   #2
hrc200x
Re: vacuum hose for vents and defroster
The ones I've seen attach to a vacuume fitting on the top of the intake behind the carb. Somtimes the one fitting in the intake has 2 or 3 different spots for different vac. functions or the main line has a "T" in it. There should be a vacuum line supplying vac to the controler, some trucks also had a round vacuum resivour. I think I've seen them mounted either above the heater core on the outside of the cab, or over by the fuse box on the outside of the cab.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 07-19-2013, 05:07 AM   #3
donut
donut's Avatar
In short, yes.
There is supposed to be a vacuum res (ball), but mine broke, so running off straight manifold vacuum now. There is what appears to be a check valve? cut into the factory line. function would have to be investigated.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-19-2013, 07:19 AM   #4
chengny
chengny's Avatar
These might help:
The check valve is to prevent loss of vacuum (used to position the HVAC dampers) during times of low intake manifold pressure - i.e. at WOT.
chengny is offline   Reply With Quote
