Old 07-18-2013, 10:13 PM   #1
IntegratedTJ
IntegratedTJ's Avatar
Rebuild or Buy New?
So just recently my father and I have started working on our old 1972 fleetside, long bed c10. We've got a 5.7l 350 sbc in it and we're stuck deciding between a rebuild or replacing rings/pistons or just scrapping the engine and getting a new one. Large amounts of white smoke come out of the exhaust upon startup up until it's relatively warm/operating temperature. Figured that this would be caused by worn rings or pistons or a blown head gasket or all of the above. The compression in the engine is bad. Compression tests also showed signs of worn rings (Starting around 70, jumping up to 120 after three tests. Compression is pretty spread throughout, up to 30 between each on the third test.) School is coming up soon and we'd like to figure out if this is worth rebuilding or even reasonable as far as cost, what we'd do to go about it, and if this block is even reusable. I can answer any questions and any help is greatly appreciated. (I'm 16, turning 17 in a couple days. Just now getting in to the craft, love it so far, just need a few pointers.) Thank you in advance.
Another thing: This truck had been sitting for 8-9 years before we fired it up a few weeks ago.
-Trever
IntegratedTJ is offline   Reply With Quote
Old 07-18-2013, 10:31 PM   #2
mmiddle
mmiddle's Avatar
Re: Rebuild or Buy New?
Welcome! I bought my first 69 when I was 16 as well. That was a long time ago.
Has the engine ever been rebuilt? Is it the original engine? Do you/dad have the skill/knowledge and tools to rebuild it?
Take a serious look at these questions before wading into the engine building pool. It may be better (and often is) to buy a new GM crate engine. There is little to compare to a 3year 360000 mile warranty.
The good thing is the SBC is the easiest engine to rebuild and plenty of parts and information are widely available for you to learn.
Being young, just don't get starried-eyed with all the performance parts out there. Build a nice solid engine that meets your needs.
Don't get sucked into the crowd that believes "If more is better, then too much is not enough"!
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-18-2013, 10:31 PM   #3
Wrenchbender Ret
Get a new GM Goodwrench engine. It is all new & they run forever. You can't rebuild one for what they cost.
Wrenchbender Ret is offline   Reply With Quote
Old 07-18-2013, 10:41 PM   #4
knsmodels
I make Models
knsmodels's Avatar
If you have the tools there is nothing better for father/son bonding than rebuilding a motor. You will learn more by rebuilding for troubleshooting in the future. If time constraints or lack of tools do not allow this then by all means buy the crate engine....good luck with whichever way you go....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 07-18-2013, 10:42 PM   #5
IntegratedTJ
Thanks for the welcome and the quick responses.
The engine has never been rebuilt, it is the original. My dad has rebuilt a couple of engines before, but that was.. 20 years ago. His knowledge has faded and we don't have all of the proper tools, but do have most. We'd just have to buy a few of the specific ones just for engine rebuilding. We are also on sort of a budget. We're leaning more towards buying a book and rebuilding it. For knowledge, bonding time, and pride. What would be some things to look for as far as knowing if the block is even reusable? Should we take the engine to an automotive machine shop and have it inspected professionally?
Old 07-19-2013, 07:30 AM   #6
big d's red67
big d's red67's Avatar
I always say rebuild, that way you know whats been done. There really aren't any speacial tools needed for a rebuild, if you need something like a puller or something most parts places [ie. Auto zone] have a tool loaner program. I agree with the pride part too. I have never belived it coast less to buy a good quality create motor than rebuilding it your self, I built my 454for about $1500 less than a comparable create motor. Let your local machine shop check you block to make sure it is rebuildable.good luck with your build.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 07-19-2013, 08:53 AM   #7
volksworld
half the battle is having a competent machine shop you can trust with fair prices...an option many folks in one horse towns don't have....old,worn out tooling on seat cutters and other equipment ,knurling guides that should be replaced,improper honing techniques ,re-sized rods that aren't square ,grinding heads instead of milling them, your motor was the one they let the "new kid" do,or good shops whose regular race car customers need their motors back by the weekend ,so yours gets skipped over for months....and when you get it back its twice the price cause its been so long they forgot what the estimate was and "prices went up"...this stuff will result in an engine that burns as much oil when your done as it did originally...as they tell you "the rings just have to seat"....finding a good machine shop is harder than finding a good mechanic...that's why crate motors are so popular,they're available immediately and theoretically are built properly(give or take my genuine GM LS-6 that was supposed to have a 500 lift solid cam, and had a bone stock hydraulic with solid lifters ...but that's another story...)
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-19-2013, 10:14 AM   #8
Lattimer
Lattimer's Avatar
You will put $1000 minimum into a rebuild, probably closer to $1500. Then you get one hassle after another. 350's are a dime a dozen, and I personally wouldn't rebuild one. I'd go crate motor every time.
I'm personally most of the way through a rebuild on a 327, and the only reason I'm doing it this way is because its a 327, and I have an emotional attachment to them. If it was a run of the mill 350, I would have gone crate engine in a heartbeat. You can get a decent 350 to your door for under $2000.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-19-2013, 10:37 AM   #9
Ridgeclimber
Take a look at these engines https://www.sandjengines.com/. I've bought a few of these and put them in with no problems. They have good, quick service with a good price. Can't rebuild it yourself for what they charge. It's cheaper then a GM crate engine with a better warranty.
Ridgeclimber is offline   Reply With Quote
Old 07-19-2013, 10:57 AM   #10
kxmotox247
kxmotox247's Avatar
That's all the truth. In addition, I work at a machine shop and it's amazing how even our most experienced machinists (35 yrs) can read tools differently. Same micrometer... different results. There is a "feel" to using precision measuring equipment. Routine verification/calibration of measuring tools is extrememly important. I'm not impressed with my local shops.
Last big block I had machined... burned a quart every 200 miles. Unacceptable. I had them assemble the short block too. The best we could figure out was that the valve seals failed and the motor was sucking in oil while the intake valves were open. This was supposedly a top notch shop but I was given a lesser priority. I feel like he gave me rushed work and that's where the problem began since his primary buisness was the local racers.
I like the idea of taking the engine apart at least. Even if you buy a crate... it's important to have hands on time learning how it all works and fits together.
kxmotox247 is offline   Reply With Quote
Old 07-19-2013, 11:14 AM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
If I had to do it again, Id buy a GM engine. JMO
John
1999 Toyota Tacoma 4x4
Old 07-19-2013, 12:00 PM   #12
cdowns
cdowns's Avatar
have seen quite a few threads over the years with those great father son rebuilt engines lasting less than a thousand miles with no warrenty and SOL for a fix
Old 07-19-2013, 02:33 PM   #13
IntegratedTJ
Appreciate all the replies, thanks a lot!
Old 07-19-2013, 03:13 PM   #14
Scamlee
Welcome Trever!! I'm 18 and I recently rebuilt a chevy 350 for my C-10 and it was a great learning experience. I'm also new to the art. Like I said, rebuilding an engine is a great learning experience and you learn a lot from it. In most cases it's the more expensive route, but you'll use that knowledge later. But, the cheaper and more reliable choice is to probably get a crate motor or a low mileage EFI vortec out of a junk yard. There is a little modification that has to happen, but its better.
Scamlee is offline   Reply With Quote
Old 07-19-2013, 04:27 PM   #15
gale
In 20 years I doubt your dad's knowledge has diminished. It has probably gone the other way but you'll see that as you work together.
Take the engine COMPLETELY apart and take individual parts to an automotive machine shop. The block will be bare so ask them to boil it out and test for any cracks. They will take a measurement and let you know if it needs boring. If so, you need new pistons and rings. The crankshaft will almost certainly need grinding and they will determine how much to take off to get clean journals. The camshaft may need to be replaced. Lifters may need to be replaced. Have them check out the oil pump. Good idea to replace the water pump as they are cheap and prone to go.
If your budget can stand a torque wrench buy a good one. It makes no sense to buy a cheap torque wrench you don't trust.
Same advice goes for all other tools. You may borrow or rent them but chances are this is just a beginning.
I switched to Snap On tools in 1974. I still add tools all the time but I still have about 98% of those I bought in '74.
Good luck and there's plenty of help for you.
gale is offline   Reply With Quote
Old 07-19-2013, 05:51 PM   #16
gale
It usually costs to learn, sometimes a lot. I had a good friend, now dead, who tried hard to be a good mechanic but as I remember it his measurement of skill was how quick he got the job done. A couple of times he just put a gasket on backwards and blocked passage of oil or water. But he learned to pay maybe too much attention to gaskets.
I fixed his screwups without mouthing a lot of things I wanted to say, like 'slow down' because he knew he screwed up without me driving it home.
With me doing most of the mechanical and body work we restored a '54 Chevrolet pickup. When the time came to put an engine in it his money was tight. I suggested to go to junkyards and get a serviceable engine that could be rebuilt at a later date. We did and I removed rocker covers from a few heads before deciding on one with a 2 barrel carb. We steam cleaned it, put it in the truck and ran it for years.
If I was in the market today I'd do the same thing.
If I buy a crate motor all I learn is how to balance my bank account.
Old 07-19-2013, 07:49 PM   #17
IntegratedTJ
Thanks a lot for the advice. Really looking forward to digging in to this thing and spending hours working on it and learning about it.
Old 07-19-2013, 08:20 PM   #18
gale
You'll never cease to learn. When you do you're probably ready to be covered with dirt. I'm 72 and still thoroughly enjoy my trucks and motorcycles. My '67 truck is a rust bucket but that changes a little every day.
Old 07-20-2013, 11:15 PM   #19
Hubscrub
Cruzin
Hubscrub's Avatar
I would rebuild, me and dad have always built our motors. I built my last for well under what I could buy a "new" one for. The time with dad and learning is a wonderful thing and you can be proud of it. We live in a throwaway world now I rebuid every thing I can carbs, starters, alternators, engines etc... and have many years of service with them.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-21-2013, 12:54 PM   #20
treveiger
treveiger's Avatar
I didn't know anything when I started working on cars seriously it was bad . Now my family thinks of me as their persional mechanic. Nobody wanted to help me start working on cars but I started asking around when I was 16 for information on how to get started now I'm 22 and seriously I'll pretty much attempt anything that's reasonable. When I got mt truck I had no knowledge on these things until I came here. Now I've taken out my drivetrain and motor to go through it all and take apart and check my motor so I knew nothing was wrong and am proud to say after two years everything is still running strong. If your gona rebuild the motor buy this right now and study this thing like crazy:
How to Rebuild the Small-Block Chevrolet:... How to Rebuild the Small-Block Chevrolet:...
I did not know how to rebuild a motor but after this book and dvd I did it just fine. My whole family was amazed I did this if I can do it any monkey can. Just do a lot of research before hand and get a GOOD HIGH END TORQUE WRENCH without one you might as well not try this.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 07-21-2013, 12:57 PM   #21
treveiger
treveiger's Avatar
Ok link no workie so go to amazon and copy and paste this in the search
How to Rebuild the Small-Block Chevrolet: Step-by-Step Videobook (S-A Design Video Workbench) (S-A Design Workbench Series)
Old 07-21-2013, 02:20 PM   #22
IntegratedTJ
Thanks a lot! And I've already learned a lot as well. Also started off knowing nothing, now my knowledge about vehicles is advancing quite well. Assume I'll be in your shoes in a couple years, too hah. Thanks for all the replies, going to rebuild and keep it updated on here!
Old 07-21-2013, 02:39 PM   #23
rcrahn
rcrahn's Avatar
Another place for great instructional videos is boxwrench.com
Best wishes....
rcrahn is offline   Reply With Quote
Old 07-21-2013, 04:43 PM   #24
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You cannot build an equivalent engine to a crate for less money. They are assembled on the line at GM with every single part brand new. From the bolts holding the valve covers on to the drain plug. Every single part in between is brand new. No one anywhere can touch that for the price.
Just because someone has rebuilt an engine for less money, don't assume they came out with a better deal. Few rebuilds really address all of the wear in an engine. You can spend half the price of a new crate engine just on rebuilding a pair of cylinder heads alone. New guides x 16, valves x 16, springs, keepers, retainers and all of the machine work aint cheap. Then you need to rebush your rods and resize the big ends. Machine the crank. Buy all new wear items, Press pistons onto rods. Cam and lifters, oil pump, timing components. Clean and repair and bent or warped tinwork (oil pan, valve covers, timing cover). It adds up to way more than a crate.
Old 07-21-2013, 05:26 PM   #25
CastIron
CastIron's Avatar
As a professional auto technician with 20 years experience, I would say buy a crate motor. That's what I'm going to do eventually. A 350 is the cheapest v8 to build, but it will still cost as much as a basic 350 crate motor. I still haven't decided which one I'll put in my '69 GMC, but I really would consider getting a 1986-up style one with a one piece rear main seal. It's a little more, but probably worth it if you plan on using it a lot.
CastIron is offline   Reply With Quote
