07-18-2013, 11:57 PM | #1 |
Rack and Pinion switch
I have a 54 truck with an original fatman crosmember 16" on center. I am switching to an 88 T-Bird power rack. I know I need the offset bushings or elongate the hole on the passenger side crossmember. The 88 unit looks different from my 76 power rack. Is their anything else I am going to have to change, like shortening or lenghthing the steering shaft. Please let me know if you have done this swap or have any suggestions. Also I use GM steering fluid and have had no problems. I am using a ford type rack just as I used with the old unit. Thanks for the help.
07-24-2013, 07:17 PM | #2 |
67-72 parts collector,…
Re: Rack and Pinion switch
Anyone?
07-25-2013, 01:11 AM | #3 |
The spline is the same, 3/4" x 36 spline. The P.S. hose fittings may be different. The T-Bird rack will have metric O-ring fittings. 14mm - pressure, 16mm - return. Earls, Summit, Motorstate, and us at No Limit have adapter fittings that convert the racks to #6 AN. You are correct that the drivers side mount stays in the same place. I'm not sure the offset bushings will do it all from the pass side. (don't know, but they sell two in a pack, so I guess that each has a 1/4" offset). You can cut the pass side rack mount off and move it.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
08-06-2013, 08:34 PM | #4 | |
