Old 07-19-2013, 01:29 AM   #1
Rnd
THM 400 to 700 R4 conversion
I just finished up the paint and cosmetic work on my 1977 GMC 20 Crew Cab (see pics thread).
Took it out for a 60-70 mile ride and no surprise, the fuel mileage sucked and it turned some relatively high rpm's on the thru-way.
I'm thinking of swapping out the 400 trans. and installing a 700 R4.
I see Monster Trans company has a conversion "kit". Has anybody done this?? If so what should I be looking for in the way of unforeseen expenses??
Tech. info:
454 stock (for the time being)
400 trans
4:10 floating rear axle
2 WD
Any thoughts or input from anybody that has first hand experience would be greatly appreciated.
Thank you,
Rnd is offline   Reply With Quote
Old 07-19-2013, 10:15 PM   #2
jimbonice
jimbonice's Avatar
Re: THM 400 to 700 R4 conversion
I have a 700r4 in my C30. Plan on doing a good build with a decent torque convertor, corvette servo, good clutches, etc. Other than changing the yoke and fabbing a driveshaft, I had no great expenses.
jimbonice is offline   Reply With Quote
Old 07-19-2013, 10:47 PM   #3
midnight rambler
midnight rambler's Avatar
Ive been thinking of doing this swap as well i currently have a 4 speed. I will most likley pay a transmission shop to do it for me as i dont even have the time to drive the truck. I will keep an eye on your thread.
midnight rambler is offline   Reply With Quote
Old 07-20-2013, 02:37 AM   #4
bluex
bluex's Avatar
[IMG]https://lh3.googleusercontent.com/-oAyZICxD69E/UenumZBvsJI/AAAAAAAAElo/8Cc0fNmH4e8/w800-h600-no/IMG_20130714_161343[IMG]
WOW! Beautiful Dually!
I swapped over mine to a 700 and I dont know what all is in monsters kit and what it costs but I got my TV cable stuff from Bowtie overdrives and I hightly recommend them, the trans and converter from a local shop and the lockup stuff I got from a friend that worked at the dealer and wired it up myself. I cant remember what it all cost but it wasnt to difficult to do, just slide the crossmember back and drill new holes. I had to have my driveshaft shortened as well but I also convereted my truck to a short bed at the same time.
bluex is offline   Reply With Quote
Old 07-21-2013, 08:32 AM   #5
Jonboy
Slots go on anything!
Do you remember how much had to come off of the driveshaft? I am getting ready to do something similar, but wanted to make sure the driveshaft would work. (5.3 and 4L60E swap).
1974 Jimmy- 5.3/4L80e/NP241
Old 07-21-2013, 09:07 PM   #6
SCOTI
SCOTI's Avatar
Jon... If I recall, you'll also be swapping in a 12bolt?? The lengths will be different because the differentials are diff sizes too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-21-2013, 09:19 PM   #7
mrolds88
Instead of going 700r4 in a heavy vehicle like that crew cab, why not do a 4L80E? Easiest way to accomplish is to use the trans computer out of a 91-93 diesel truck. That way you dont have to get all the high end parts for the 700.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-22-2013, 09:01 AM   #8
Jonboy
This is true. From what I have read, there is only 1" difference between the 6" tailshaft TH400 and a 4L60E. I just wanted to make sure I didn't need to get the front half of the driveshaft shortened at the same time I do the rear. I will be using the Dirty Dingo sliding mounts, so it may be a non issue.
