Old 07-19-2013, 01:37 AM   #1
Tortuga_64
Tortuga_64's Avatar
Front Disc Brake conversion *Please Help*
I recently did a front brake conversion on my 64, I used spindles off of a later 60s to 70s truck, not sure of the year. The bolt pattern of the rotors is a 5 on 5, I'm looking to convert it to 5 x 4.75 to use the wheels that i want. I've read somewhere you can use a rotor off of a chevelle or another application on the the spindles that i have and it will convert it to a 5 x 4.75. Any help or ideas would be greatly appreciated
Tortuga_64 is offline   Reply With Quote
Old 07-19-2013, 06:03 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front Disc Brake conversion *Please Help*
The conversion you are talking about is a bracket that attached to a DRUM brake spindle, and uses a chevelle rotor and camaro caliper.
You would have to put your drum brake spindles back on.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 07-19-2013, 06:05 AM   #3
lolife99
lolife99's Avatar
The other option is to use a 73-87 LIGHT DUTY spindle (1" wide rotor),... with a '92 Camaro 1le only rotor.
Keith
Old 07-19-2013, 09:58 AM   #4
Tortuga_64
Tortuga_64's Avatar
Thank you very much for the info, unfortunately i trashed the drum assembly's including the spindles and I think I have the heavy duty spindles Guess I'll be hitting the classifieds and Craigslist.
Old 07-19-2013, 11:07 AM   #5
lolife99
lolife99's Avatar
Personally I would just run a 5x5 wheel.
It's not worth the expense to switch to the 5x4.75 bolt pattern.
What are you going to do for the rearend?
Keith
Old 07-19-2013, 11:59 AM   #6
Tortuga_64
Tortuga_64's Avatar
I was planning to switch out the gears, put a posi in it with new axels and possibly narrow it a bit. so with new axels i can have whatever bolt pattern..... that is down the road tho as i am on a budget like everyone here. I bought a new set of wheels this week and my plan is to go flat black with the truck with 3" wide white walls sitting on red corvette rallys with the derby caps and possibly beauty rings. This week I got a great deal on 15 x 10s for the rear and i have 15 x 7s for the front. However corvette rallys are 5 x 4.75, which lies my dilemma.
Old 07-19-2013, 12:35 PM   #7
lolife99
lolife99's Avatar
I would still buy 2 aftermarket corvette style rallys in the 5x5 pattern,... before I would switch the front to 5x4.75.
Just my opinion.
Keith
Old 07-19-2013, 02:02 PM   #8
gofastnut
gofastnut's Avatar
TRANSDAPT makes a 5x5 to 5x4.75 adapter to do what you want. Here's the kicker: they are 1.25" wide each.
P/N 3614 $125/pr
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 07-19-2013, 02:57 PM   #9
lolife99
lolife99's Avatar
My opinion,... Spacers/adapters will make the front track width too wide.
Keith
Old 10-13-2013, 12:15 AM   #10
elf w/capital T
Not to thread jack, but one day ill find out and ill help you!!
Im trying to figure out WHAT front suspension the PO put on, I HAD 4.75 all four, got 5x5 rear, 10 in wide rallies now,, but i want to keep my front 8 in rallies upfront, just not a clue on which car they swapped with!
elf w/capital T is offline   Reply With Quote
Old 10-13-2013, 12:18 AM   #11
elf w/capital T
And in that picture, both front and rears have spacers, i am thinking just go 73-80 whole swapper-oo and have them plugged and redrilled to fit my 5x4.75 rallies...
Old 10-13-2013, 12:32 AM   #12
Captainfab
60-66 Nut
This thread might help some........
http://www.67-72chevytrucks.com/vboa...d.php?t=319487
Old 10-13-2013, 05:02 AM   #13
familyfast64
familyfast64's Avatar
Can't you just have the rims drilled for both sizes?
Live and let live
familyfast64 is offline   Reply With Quote
Old 10-13-2013, 11:52 PM   #14
Captainfab
60-66 Nut
I've never heard of someone having their wheels drilled for a second bolt pattern. I've seen wheels from the manufacturer with dual bolt patterns. It would be more cost effective to just change the rotors as described in the thread I linked to.
Old 10-14-2013, 08:12 AM   #15
elf w/capital T
Old 10-15-2013, 11:26 PM   #16
66 C10 383
Just a heads up, you might want to verify what the bolt pattern is on the 15x10's. Stock Vette rallies were never available in a 10" width, only in the 8". That would mean they are either widened stock wheels or aftermarket and could be 4.75" or 5x5 bolt pattern ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 10-16-2013, 09:48 AM   #17
kieth
kieth's Avatar
Drill the 4.75 pattern in the front rotors, move the studs to the new holes. It is really simple, if you want to keep the 5.5 pattern rotors go to the parts store and buy new ones, they are only $17.00 at O'Reilleys I converted both front and rear on my truck to 4.75 x 5 drilled the front and rears both...Kieth
kieth is offline   Reply With Quote
Old 10-16-2013, 10:32 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've seen wheels re-drilled but its not really that simple. Most of the time it is part of a much larger custom wheel job. I.e. I've seen custom shops take a rare factory wheel, and put it in a new hoop/barrel and widen it, then re-drill to work with a differennt platform...but its not simple machine work. Some patterns can't be re-drilled, some wheels don't have room on the mounting face without actually trying to fill in the old holes (nightmare).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-17-2013, 06:53 AM   #19
elf w/capital T
My 10 inch rallies are 5x5, unlike the 8 inch ones i had...5x4.75
