Old 07-19-2013, 09:47 AM   #1
SuperCtruck
SuperCtruck's Avatar
suggestions or tips when considering IFS?
Hey fellas, I have a 1949 Chevy 3100 completely original stock right now. My plans are To Bag this truck to the ground and slap a LS motor in it! I have been looking at numerous IFS kits and airbag system's but can't figure out which would be the Best bang for the Buck$$?!! I also want to go with a four link rear on bags in the back.. Any suggestions would greatly be appreciated
SuperCtruck is offline   Reply With Quote
Old 07-19-2013, 12:25 PM   #2
Chris.
Re: suggestions or tips when considering IFS?
I have a Scott's hot rods superslam IFS, I love it!
Here's my build thread it has pics on the IFS
http://67-72chevytrucks.com/vboard/s...d.php?t=553572
Chris. is offline   Reply With Quote
Old 07-19-2013, 12:42 PM   #3
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
I have used 2 scotts front ifs air bag set up and rear 4-bar.great stuff.talk to justin.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-19-2013, 03:09 PM   #4
SuperCtruck
Sick builds guys Sounds like Scott's ifs is the answer! I wast sure about the C notch in the back of the frame, I though I could just notch the bottom part of the frame instead building a square tubing c notch? Anyways I will defiantly be taking notes before I tackle this build! 1st I have to finish my 71 camaro
Old 07-19-2013, 03:15 PM   #5
Scottshotrods
Buy a Quailty built frontend made in the USA.
Deal with company you can call and get people on the phone.
Buy a frontend that is built for your truck.
Here is our Contac #(805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 07-19-2013, 04:10 PM   #6
Daze57
Daze57's Avatar
^ good answers justin !!!!!
Daze57 is offline   Reply With Quote
Old 07-19-2013, 04:39 PM   #7
fabguy
Elev8r Man
fabguy's Avatar
Flat out engineering criss member and a C4 kit is another option, also one that I might go with
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 07-19-2013, 05:19 PM   #8
mr48chev
mr48chev's Avatar
Buy the best setup that is Made in the US by a quality manufacture that your budget can afford. And the most complete package at the same time.
On the C notch thing. With your bare frame laying on the running board supports on the shop floor you need to measure from the floor to the bottom of the frame right above the spot where the axle goes under and then measure from the floor to the top of the axle sitting beside it with the wheels and tires (or same size) on it that you are going to run when the truck is done. Add an inch for clearance and you have how deep the notch should be. I've often pondered why guys feel they need notches that end up several inches above the axle with the frame laid out on the floor or ground.
My ongoing truck projects:
Old 07-19-2013, 05:41 PM   #9
SuperCtruck
I always wondered why such deep Notches etc....Idk? Great advice, thanks
Old 07-19-2013, 05:44 PM   #10
SuperCtruck
Justin
Ill be in touch with you hopefully in the next 6 months Justin! Thanks
Old 07-19-2013, 07:23 PM   #11
Scottshotrods
Sounds good
Justin
