Old 07-19-2013, 11:28 AM   #1
chris1htx
bed liner
anyone know of a place that sprays bed liners in the Houston area?
chris1htx is offline   Reply With Quote
Old 07-19-2013, 11:31 AM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: bed liner
Have you looked at 4 wheel parts over off 610? I know there's a place in Pasadena that does them, not sure if you want to be driving that far though.
I just used googled found about 6 here in houston here's the names of each
toffcustomliners
armidallo liners
west houston rhino lining
ultimate linings
truck gear superstore
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 07-19-2013, 11:44 AM   #3
chris1htx
Re: bed liner
have you used 4 wheel parts before? do they do a good job?
Old 07-19-2013, 11:50 AM   #4
77ChevySharkBite
Re: bed liner
I haven't personally used them, I just know of the building because I've been there a few times with friends to look at stuff for there truck or jeep.
I find there products to be a little on the high side but thats me.
Korwin
Old 07-19-2013, 11:57 AM   #5
chris1htx
Re: bed liner
i've been debating on whether or not i should spray the liner on the very top of the side walls. i was thinking of just having the liner sprayed to meet the top but not actually go on top. the truck is hardly going to be used to haul things around. what do you think?
Old 07-19-2013, 12:26 PM   #6
77ChevySharkBite
Re: bed liner
Yeah just go to the top of the side walls no need to spray the whole thing unless your going to use it like you said.
Korwin
Old 07-20-2013, 06:35 AM   #7
andrewmp6
Re: bed liner
If your talking about over the top of the bed sides i wouldn't.And look at line-x brand its harder and won't have any runs at all,Rhino lining is a little thinner and can get runs sometimes.But ether way pre sand the bed yourself before you get it sprayed.Reason i say that i have seen one or two they missed a spot sanding and the lining lifted but it was small spots nothing big.
andrewmp6 is offline   Reply With Quote
Old 07-20-2013, 05:27 PM   #8
caramaro
caramaro's Avatar
Re: bed liner
i did the whole thing on my 87 myself it's not that hard to do. i went on top of my bed caps simply because i've hauled stuff before and it does get damaged.
caramaro is offline   Reply With Quote
