Am I overthinking this???
Problem: I'm an Engineer and tend to overthink things...
Truck is a '71-'72, basic plans are DM, 20s or 22s, 383, 700R4, and two-tone paint with trim. I've received my PB Mild front and rear kits, McGaughy's 2.5" drop spindles, and Wilwood D52 and D54 brake kits. I have the bed and cab off the frame and am going to be pressure washing the frame and removing the motor and tranny next, then the fun begins. This is my plan, hoping for confirmation, "what the hell are you thinking?", or "you might want to think about this" comments please: 1. Level frame on stands and install front DM, put motor and 700R4 in to set engine/tranny angle; 2. Install rear DM and set pinion angle (directions say it needs to be at ride height to set pinion angle); 3. get brakes and rotors mounted; 4. put body panels back on to confirm and decide on wheel size/BS and start raising bed floor. Is it an issue that I have to set the pinion angle before I confirm ride height and tire size? I don't want the front wheels tucked too much. My concern is having a decent turning radius, so making sure I have that will dictate ride height and wheel size. I know that I will just be tack welding the rear DM axle pieces in place, so I should be able to adjust a little as needed, right? I've searched for turning radius with 22's and found a little, but as many have said you have to measure your truck, so that's what I will be doing. Am I overthinking this?? As always, thank you for any insight! |
![]() Join Date: Jun 2013
Re: Am I overthinking this???
You lost me with PB and DM.
The transmission can decide the engine height for you. A torpedo level on the intake manifold can decide the angle. Life will be simpler if you keep the carb level. The pinion angle should somewhat match the angle established at the transmission. That makes the U-joints work less. |
#3 | |
I've researched the engine/tranny and pinion angle and if I remember correctly from a PB post it should be about 2* for both (one down and one up obviously). |
67-72 parts collector,…
![]() Join Date: Nov 2002
Call Nate Porter at Porterbuilt.
He will be happy to talk to you about your concerns. What other suspension company can you talk to the owner, designer, engineer, and fabricator,... all in one call?
#5 | |
![]() The only thing I would recommend to do differently is wait to permanently set the engine/trans angle and rear diff angle until you have the driveshaft. This will allow you to set it once as there may be some fine tuning involved. Nate Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#6 | ||
Again, thanks for the input! |
#7 | |
Don't hesitate to call... true we don't have a 24 hr tech line, but if you leave a message you will get a call back. And don't be afraid to call more than once if you feel you have been waiting too long for a call back! ![]() Nate
