Old 07-19-2013, 03:54 PM   #1
Midgets50
Midgets50's Avatar
rochester carb rebuilding??
Hey guys, so i went to the local auto parts store and they cant find me a carb rebuild kit for my single barrel rochester that is on my 235. Where do you guys get your rebuild kits from. i was hoping i could get one from like o'reillys or something
Midgets50 is offline   Reply With Quote
Old 07-19-2013, 03:57 PM   #2
mechanixman
mechanixman's Avatar
Re: rochester carb rebuilding??
I got mine at Napa
They should have them at oreilly, but it takes a while for them to ship it to the store
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 07-19-2013, 04:00 PM   #3
Midgets50
Midgets50's Avatar
alright. cool. thanks nick. would you happen to know the parts number. and did you have to buy the float and needle separate or did they come in the kit
Old 07-19-2013, 04:04 PM   #4
mechanixman
They came in the kit
It was about $16
-Nick
Projects:
Old 07-19-2013, 09:00 PM   #5
Rednek13x
Rednek13x's Avatar
If your getting the 17 dollar kit, most likely you are not going to get the float.
Rednek13x is offline   Reply With Quote
Old 07-19-2013, 10:20 PM   #6
mr48chev
mr48chev's Avatar
I've been at this for over 50 years and rebuilt a couple hundred various carburetors and never once got any kit with a float in it. You might get one from one of the specialty vendors but not through regular sources.
Midgets50 most likely you have the carb that takes Kit #4 and float #5.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=84
Chevs of the 40's
https://www.chevsofthe40s.com/detail...Rochester.html
Float
This is pretty interesting as it shows carb numbers but his kit is rather spendy by comparison. http://www.carburetion.com/Kits/chevy.htm They also show less expensive kits and floats though. Put your carb number in their search and you should find some info.
Asking for the kit by Carb number at Napa, O'reilly's or Carquest should help narrow things down too. If there is an older independent parts house in the area check there as usually they use the books rather than rely on the computer and while the part may not be in the computer it is most likely in the paper catalog.
My ongoing truck projects:
Old 07-19-2013, 10:53 PM   #7
mechanixman
Oh my bad, I thought Midget50 said needle and seat
-Nick
Projects:
Old 07-22-2013, 09:46 AM   #8
Greaser50
Standard Hygrade kit for a 216 Rochester RP is 123a. The kit will work for a 235 RP also but the base plate gasket is different.
Greaser50 is offline   Reply With Quote
Old 07-22-2013, 10:01 AM   #9
mr48chev
mr48chev's Avatar
Putting the 123A from Greser50's post in the www.naponline.com search and clicking the interchange box brings up these kits.
http://www.napaonline.com/Catalog/Ca...23A_0365604990
http://www.napaonline.com/Catalog/Ca...158_0364850163
The MPF312A_036504990 appears to have a good assortment of gaskets for multiple applications even though it is their "discount" kit.
Old 07-22-2013, 10:41 AM   #10
focusedontheprize
focusedontheprize's Avatar
That is where I bought mine. No problems at all.
focusedontheprize is offline   Reply With Quote
Old 07-22-2013, 10:59 AM   #11
Midgets50
Midgets50's Avatar
well i got mine from o reillys for $24. he said its supposed to have everything in it. so i guess i will see when i start rebuilding it
Old 07-22-2013, 11:06 AM   #12
mechanixman
Cool
Keep us posted
Old 07-22-2013, 11:19 AM   #13
Greaser50
Now if someone could find a good kit number for some Carter W-1s. I spent about 2 hours looking for some ,with no lock.
Old 07-22-2013, 11:48 AM   #14
Yewhi
The best kits I've gotten have been from Mike's Carburetor parts.
http://www.carburetor-parts.com/B-BC...rts_c_146.html
One of the other reasons I support him is he's put together a number of very helpful videos. Not everybody needs these but I've found them very, very useful. Link the Robchester B videos is below.
http://www.carburetor-parts.com/Roch...BV_ep_350.html
Cheers!
Yewhi is offline   Reply With Quote
Old 07-22-2013, 09:01 PM   #15
joe70
joe70's Avatar
X2 Mike's carburetor for either rochester or carter single barrel.
joe70 is offline   Reply With Quote
Old 07-23-2013, 11:07 AM   #16
Divine 59
Thanks for the info on Mike's. I will support his business when I need to buy carburetors and parts for my truck.
Divine 59 is offline   Reply With Quote
Old 07-23-2013, 12:07 PM   #17
Midgets50
Midgets50's Avatar
^x2 he makes a really great video on rebuilding the carb. had i known about him before i got my kit i definitely would have order my stuff from him
