Old 07-01-2003, 07:06 PM   #1
68CST327
Cam Choices For 327
(darn search function being disabled )
Well, I'll be in the market for a cam soon. When I had my truck at the mechanics last time he said the lobes on my cam were pretty worn down. Major power robber So when I get enough money saved up, it's time for a new cam (and while I'm at it, maybe new heads and rods too ).
I seem to remember the Crane Energizer 272 being highly recommended for a 327. Sounds pretty good to me:
http://store.summitracing.com/partde...t=CRN%2D100052
Any suggestions?
68CST327 is offline   Reply With Quote
Old 07-01-2003, 08:56 PM   #2
cableguy0
i wouldnt run that cam in a stock motor with stock heads and a stock convertor it will actually slow you down look for something with under 220 duration @.050 the lunati truck avenger cams are a good grind for a truck unless you plan to do other mods that cam is too big for a truck
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-01-2003, 10:10 PM   #3
68CST327
Yeah, I'm thinking about the World Products S/R Torquer heads combined with around a 2200 rpm torque converter.
Old 07-01-2003, 11:50 PM   #4
crazy longhorn
Fabricate till you "puke"
I ran the Energizer 272 in a 327 , with a set of z 28/lt1 castings. the truck had 3.73 gears, & a saginaw 4spd. 216 dur @ .050, & a mid 450s lift gave it a slight cammy sound (more so when cold). that thing pulled like crazy! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-01-2003, 11:57 PM   #5
68CST327
Actually, the Crane cam has a 216 duration @.050.
[EDIT] Noticed CL posted that already.
Old 07-02-2003, 10:31 PM   #6
Eddie H.
Eddie H.'s Avatar
I personally prefer the old reliable factory 350 horse 327 hydraulic cam that was used in the mid 60's Vettes, Very driveable and they make the little 327 run like a scalded dog. They're still available from GM and Crane also makes a copy of it.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
