Old 07-19-2013, 05:07 PM   #1
jpmanyhearts
frankenstien Fabrications
stock 4x4 question
I have a stock 4x4 that I want to lift up a little just to give it a good look is all I know I will need maby blocks in back but do you put blocks in front ? im thinking 31x10.50s any suggestions would be great thank you
frankenstein Fabrications
jpmanyhearts is offline   Reply With Quote
Old 07-19-2013, 05:11 PM   #2
b454rat
Re: stock 4x4 question
31s will fit on a 2wd. These trucks came stock with 31s, and a 32 will fit fine. A tall skinny 33" will fit too. A 33" on stock 8" rally's with a mild 2 1/2" lift looks good IMO. I personally always liked 6" with 35s...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-19-2013, 06:10 PM   #3
79Betty
79Betty's Avatar
Good and bad. The good - blocks are easy and lift easily, cheap as well. Bad - blocks on the front of a straight axle truck are illegal. Due to the stress the front suspension sees (left to right) unlike the back (just up and down) they can kick out and possibly hit something or someone. Honestly unless you're acting stupid you'd be fine. But i'm just puttin that out there...
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-19-2013, 07:00 PM   #4
jpmanyhearts
http://memimage.cardomain.com/ride_i...0001_large.jpg
THIS IS KINDA WHAT IM LOOKING FOR WHAT DO I NEED ? THANK YOU
Old 07-19-2013, 08:02 PM   #5
AJII
AJII's Avatar
Looks like 6" and 35s..
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 07-19-2013, 09:19 PM   #6
swamp rat
swamp rat's Avatar
Never put blocks on the front, ever! not safe. 2" lift and 31's will be fine.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-19-2013, 09:21 PM   #7
swamp rat
swamp rat's Avatar
This pic looks more like a 6" lift to me, i have a 4" Rancho lift with BFG 33's and your pic looks like there is more space between the tire and top of the fender well.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-19-2013, 09:50 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'll just agree with others have said.... NO BLOCKS UP FRONT, and the truck in that pic is lifted more than 'just a little'.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-20-2013, 10:42 AM   #9
LONGHAIR
Agreed 100% do not use blocks on the front. It is a huge safety issue, but not because of what the block might hit if it came out. The problem is that you lose control of the axle. The block increases the leverage against the mounting points and U-bolts, which is why it could get loose in the first place. If the block gets loose, or comes out, the center pin is no longer keeping the axle "located". So the entire axle could move front to back, drastically changing the steering, not to mention what would happen when one corner instantly drops 2-4 inches.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-20-2013, 12:13 PM   #10
RPIcka
I got 33"s with no lift however the tires rub when the tires are turned and going over bumps. I'd like a 4" inch in the near future.
'72 K10
'94 K2500
RPIcka is offline   Reply With Quote
Old 07-20-2013, 07:34 PM   #11
jpmanyhearts
so could I do 3 lift and 3 body then ???
and does anyone have any lift or springs or shocks they would sell ???
Old 07-20-2013, 07:39 PM   #12
jpmanyhearts
this looks pretty good too
http://ts1.mm.bing.net/th?id=H.4806082321318732&pid=1.7
http://farm8.staticflickr.com/7226/7...1103fd01_z.jpg
http://i825.photobucket.com/albums/z...er/mudside.jpg this one is too high
Old 07-20-2013, 07:44 PM   #13
jpmanyhearts
http://i307.photobucket.com/albums/n...t/100_0139.jpg
I think this is close I were to put 33's on it would it look like this ?
Old 07-20-2013, 10:11 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That appears to be 33s and a 2" to 2 1/2" lift.
- Mike -
RIP El Jay
Old 07-21-2013, 12:52 AM   #15
andrewmp6
Forget the body lift and do a suspension lift.
andrewmp6 is offline   Reply With Quote
Old 07-21-2013, 09:44 AM   #16
LONGHAIR
I have no problems with body lifts. They will gain you some tire clearance for a street cruiser or mild off roader. The only negative it that the only ground clearance gain comes from the increase in tire size. If that doesn't matter, you will be fine.
Old 07-21-2013, 10:51 AM   #17
dieseldawg142
dieseldawg142's Avatar
i agree, there's absolutely nothing wrong with a body lift. keep it under 3", use real blocks (no pucks), gr. 8 bolts & it's a very good idea to swap your body mounts for poly. another option, if you don't mind cutting sheet metal- cut out fender flares, they open up the right area's of your fender & pretty much give you the equal of a 3" lift.
i would go 4" lift, if it doesn't clear, add a 1 or 2" b. lift. with a 4" lift you shouldn't have to mess with driveshaft angles or lengths, brake lines, dropped t-cases, etc.
dieseldawg142 is offline   Reply With Quote
Old 07-21-2013, 10:55 AM   #18
b454rat
I have 38.5" boggers on 12" wide wheels on my 84 with a POS 4" lift. Only rubs when flexing real hard...
