Air Ride equipment explanation
Im sorry if there is a thread about this. Please link me if there is.
But i'm about to air ride my first vehicle (61 Apache). Can somebody explain basically how the bag ratings work. Is the rating rated for that 1 corner or for the rear combined? Whats the difference is compressor ratings an what works best. I'm assuming the bigger the tank you can have the better off you are regardless? Thanks |
Re: Air Ride equipment explanation
You might already know this but just in case, 61's have torsion bar front ends and I don't think there are any conversion kits for putting bags on a 61. You will either need to modify the lower a-arms or install a new front cross member.
Thanks.
While i have your attention do you know of anywhere that sells bottles of plasma so i can get to cutting? |
Moderator
![]() Join Date: Dec 2012
You need to research how a plasma cutter works. They don't use bottles of plasma
#5 | |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Basically at the moment i'm just trying to determine what bag i need to start designing my mounting system.
This is what i had looked at http://www.ridetech.com/store/air-sp...onvoluted.html Not sure if thats to much bag, or would ride stiff? |
Plasma Cutter: A method of cutting metal workpieces with a jet of air, ionized/melted by an electric arc to create plasma.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Love that my joke gets several replies but my legitimate issue gets no attention...
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Ya know, you may be way ahead if you look for a 63-72 frame that is either done or just a frame so you can make it the way you want it. Most folks put 25/2600 bags on, 2500 on front but there are also ss6/7/8 that are rated about the same but take up more/less space in the pocket. Good luck however you choose. Oh and welcome!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Not true, I have 2 friends!
About the air ride, I dunno. Those bags look like they should work fine, depending on amount of drop/rise you want.
The frame is already somewhat built. I'm not a buy the kit an bolt it on kind of person. Just never messed with bags before and needed some guidance.
The bag i posted lists at 3400 which seems much but I cant really come across anything that has 7"+ of travel that rates over 2000lbs. |
#13 |
Amazon sells a lot of bags. I have bought several pairs of D2500 and D2600 bags there and was pleased they were Firestone bags.
As far as answering your question about tanks- the best answer I can give is it depends on how fast you want it to go up and down. If you want speed- you want a large tank and large valves with large lines(1/2") Since I do not care how fast mine goes, my 'Burb has a 3 gallon tank, 1/4" lines and valves and is going to be set up with auto leveling in the back. Compressors are the same depends on what you want to do with the system - check the ratings for cubic feet per minute of air volume for the output. High pressure rating does not always equal high volume of air output. You can get some good info on www.airbagit.com |
#14 |
I guess it should be noted that my plan is to lay frame but still be able to get up to 6-7" off the ground at minimum so I have no issues with clearance if needed ever.
#15 |
When you say 6-7" ground clearance- where are you measuring this clearance at?
That's a lot of range without some serious geometry like canti-lever but I've only seen that done on the rear, not sure how you'd achieve that on the front. I may be way off base, maybe it can be done easier than I think- just seems like a lot of travel if starting at laying frame to get to 6-7" of frame to the ground |
#16 |
I'm new to this, but in that case youre saying guys that lay frame only can raise their vehicle up to around 3" off the ground? Seems if the bag will travel x amount the vehicle should as well?
#17 |
Like I said, I may not be understanding right, either.
I know I do not have 7" of travel in the bags I have, or if I do, that is absolutely maxxed out and no way I could drive it that way-it would be way too stiff. But again, that is how I have mine, I cannot lay the frame on the ground- I didn't want to, LOL. mine stops at about 2-3" off the ground and goes to about 7 1/2 - 8" , measuring bottom of frame to ground, behind the front wheels at front cab mount. I could go lower w/ dropped spindles in front and blocks in back, if I wanted to. |
#18 | |
meowMEOWmeowMEOW
Running your ride height at near full lift means higher pressure in the bags more often. This means a much stiffer ride at ~110psi then you would at 60-75psi, a greater risk of damage (50mph + pothole+full lift = something will break, and it might be your back or wrists). The other issue is shocks. Its not easy, fun or cheap finding a shock that will go from full drop to full lift, and work WELL at full lift. IMO what you need to do is determine where you really want your REGULAR ride height. This will let you set up the control arms, bags, shocks, and all your triangulation for the rear end, and not wind up running everything ragged. Oh and bagged trucks break stuff. If you don't start with entirely new wear parts on the front end, you'll need them within months. Things like ball joints etc start to go much faster. Air ride is fun but isn't exactly a bolt-on to do right. I'd take a look at places like the s10forum.com They have MASSSIVE amounts of tech on everything air ride, and all the concepts will apply to your current project in principle.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#19 |
I understand what youre saying completely. I in no way shape or form plan to drive the thing maxed out. That would be pointless. I simply won't the ability to drive through a parking lot with speedbumps an be able to get up off the ground plenty. The ones around here tend to be a bit agressive.
