Old 07-19-2013, 10:09 PM   #1
texastrendz
Sensor on LS Intake
Is there anything that I can do with this sensor. If I can rotate it would be great. Tried messing with it tonight with no success. What does it do also would be great to know. It is to close to my firewall to plug in the connector. Hate to start hacking on the firewall again if there is an easier solution. Thanks Daniel
Its located on top of a truck manifold in the rear. Hard to tell in the pic.
texastrendz is offline   Reply With Quote
Old 07-19-2013, 10:18 PM   #2
chev3600
chev3600's Avatar
Re: Sensor on LS Intake
MAP sensor, carefully unclip it (tabs are fragile) and pull straight up. Rotate 180, reinstall.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 07-19-2013, 10:24 PM   #3
texastrendz
Could not find the clips to release it. Only played with it for a short time, tomorrow I will have to study it a little more. Thanks for the quick response.
Old 07-19-2013, 10:49 PM   #4
chev3600
chev3600's Avatar
Argh... Can't resize photo right now. Anyway, the little tabs on the sides of the sensor has hooks at the top that hold the sensor down. Pry them slightly outward. The sensor is mainly held in by a rubber seal.
Old 07-21-2013, 05:05 PM   #5
texastrendz
I can not turn the sensor 180 degrees, it will hit a mounting post right in front of it. Can the molded mounting bracket be rotated to 90 degrees or are the made into the intake?
Old 07-21-2013, 06:06 PM   #6
chev3600
chev3600's Avatar
The base is made into the intake. Don't twist. Not sure about the post in the way, mine didn't have one. Maybe someone else has a good idea on this one....
Old 07-21-2013, 07:21 PM   #7
texastrendz
I need to rotate it 90 degrees, can this be done. You would think that this would be a serviceable part just in case you broke the tabs. Need an LS guru to jump in and help a brother out. If I knew how to remove it without breaking it I could probably figure it out.
Old 07-21-2013, 09:01 PM   #8
truckdude239
truckdude239's Avatar
Good luck i broke my tabs by accident deal wants to sell me an intake. What is this in? Cause i have penty of space to hook mine up with the 3 inch dirty dingo silder mounts all the way back i still have penty of space
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-21-2013, 09:10 PM   #9
texastrendz
It is in a 68 c10 truck, the problem is its equipped with a porterbuilt dropmember and it moves the motor up from the factory location. I may have to switch to a car style intake manifold. I do not want too, but I may have to do it.
Old 07-22-2013, 11:28 AM   #10
Custom 68
Custom 68's Avatar
If you swap to a car style then you will also need to do the front accessories and water pump ... which can be a pain and expensive. I am not sure what might be in front to prevent you from moving it 180 degrees, maybe that part can be "trimmed" I don't remember what all is around mine.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-22-2013, 04:37 PM   #11
texastrendz
My problem
Old 07-22-2013, 07:39 PM   #12
texastrendz
I am going to just cut the post off in front of it. Hopefully that does not leave a big gaping hoe in my intake. I have been searching high and low for the answer. Just going to hack it. lol
Old 07-23-2013, 01:44 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wait if your asking "can I cut this"
Yes.
Plenty of intakes have been smoothed over. If your just trimming the top down with a dremel to fit the sensor and molex plug, this should be no problem. Just don't shave it all the way flush so you don't risk thinning the material out too much if you can avoid it. Plastic intakes do crack if provoked too far.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-23-2013, 02:18 AM   #14
ls1nova71
ls1nova71's Avatar
Don't cut it too far down or you could end up with a hole. What I would do is cut off the tabs that hold the sensor in, then put the sensor in how you want. Then make a small metal bracket to bolt into that bolt and go over the top of the sensor to hold it down. Doesn't need much to hold it in.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-23-2013, 09:30 AM   #15
texastrendz
I like this idea, it seems the plastic tabs are going to fail eventually. This way I will not be using them. I will see what I can do.
Old 07-23-2013, 09:41 AM   #16
Wasted Income
Boosted Member
Wasted Income's Avatar
Not true. I've done a car intake with truck accessories in the past.
This is also what I would do.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-23-2013, 12:30 PM   #17
texastrendz
Think we got something here. Thanks for all the help.
Looks like its going to work out nicely. You could actually do this if you brake the tabs off on accident
Old 07-23-2013, 12:32 PM   #18
texastrendz
Side shot
Old 07-23-2013, 12:37 PM   #19
texastrendz
Think I could sell these for half the price of an intake? Lol
Old 07-23-2013, 01:46 PM   #20
Wasted Income
Boosted Member
Nice work. That will work perfectly
Turbo diesel
Old 07-23-2013, 01:57 PM   #21
texastrendz
Bolted down. Got to rattle can and done
Old 07-23-2013, 07:53 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Nothin a little metal stock couldn't fix eh brother?
Nice quick fix, simple but functional.
Old 07-23-2013, 08:36 PM   #23
truckdude239
i'd buy one if you wanted to make another and mail it to me!
David fuller
2000 Tahoe 5.3l 378
