Old 07-19-2013, 10:32 PM   #1
slammed427
slammed427's Avatar
Burb Rear A/C in a Crew?
I'm back and forth about what I want to build for my next toy, either a roadster k5 on air, or a ls powered ccsb.
If I go with the crew, I'd like to add a rear a/c setup from a suburban. Has anyone done this?
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 07-20-2013, 01:11 AM   #2
slammed427
slammed427's Avatar
Re: Burb Rear A/C in a Crew?
After some l looking online, I don't think the burb setup would work without a ton of modding. So hmmm... Anyone have a good idea to get air to the back?
Instagram: mmmdropp
Old 07-20-2013, 03:09 AM   #3
zaccaglin
zaccaglin's Avatar
I have a complete rear AC setup I'm trying to sell should you'd like to try it, I'll be heading through Arizona in sept..
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 07-20-2013, 06:38 AM   #4
andrewmp6
Anything can be done if you try hard enough,Only thing i see being a problem is trying to tuck everything in the back of the cab.You have any measurements on all the pieces?
andrewmp6 is offline   Reply With Quote
Old 07-20-2013, 11:57 AM   #5
slammed427
slammed427's Avatar
I don't have any measurements, nor have I bought a cab yet. I just didn't realize the vents were all the way at the back of the suburban. I'd like to try and keep it simple, as a ccsb would probably end up being my dd, I know myself.
Instagram: mmmdropp
Old 07-20-2013, 12:15 PM   #6
manimal
manimal's Avatar
I think the only thing you will accomplish is blowing cold air on the back of the drivers head. rear 'burb air box is BIG. Why not come up with a center console that plums air to the rear via the floor?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-20-2013, 12:51 PM   #7
esbstuff
Alot of cars use this idea to get air to the back... or under the front seats which would just as good.
I just wish you could buy a high flow fan to move the air quicker... Cool down time seems long in a crew.
esbstuff is offline   Reply With Quote
Old 07-20-2013, 01:30 PM   #8
mrolds88
After owning square burbs and a next gen burb, I have an idea. My 96 has rear air also. But it is totally different than the square. It has the vents right behind the driver. You can also put it on front or rear control, etc. Might be interesting to take a look at it.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-20-2013, 04:02 PM   #9
slammed427
slammed427's Avatar
The 96 idea would be cool, especially if it has it's own control unit. I had thought of doing a console type too. It's all gonna come down to what I find first, a blazer tub or a crew cab body.
Instagram: mmmdropp
Old 07-20-2013, 04:44 PM   #10
Skunksmash
Skunksmash's Avatar
I think you'll be a lot better off building the rear AC setup yourself. Using bent sheetmetal welded together or something. I've considered doing this in a couple of older, longer vehicles that I want to fix up. Bout the only thing you'll get to use that's factory will be the vents, for looks.
Skunksmash is offline   Reply With Quote
