Old 07-20-2013, 12:17 PM   #1
BigRed76
BigRed76's Avatar
Questions about 5.3 upgrades
So I just got my 5.3 this week, it's a 2000 w/125K. But I have some questions about performance upgrades. The only thing I know for sure is that it will have headers and a cold air intake.
But if I were to throw in a bigger cam at what point do I need to get it tuned?
Or do you guys recommend getting a tune anyways?
If I do anything that increases air flow in/out of the engine then the MAF will see that and compensate accordingly correct?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-20-2013, 05:55 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Questions about 5.3 upgrades
To get it to run you'll have to get it tuned anyway; things like the VATS, o2's etc need to all get removed. Things like torque management and traction control also need to be fiddled with to get all your power to the ground in a swap car.
Since your already doing that, you might as well throw a small stick in it, providing you keep it conservative enough to run off stock injectors.
The tune itself is good for some HP, so its always worth it imo. Dyno tuning is the best from a power and driveability stance, and no mail order tune despite what anyone claims, will ever be as good.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-21-2013, 09:19 PM   #3
bohmankid
bohmankid's Avatar
Tune is usually always recommended after you start replacing internals with performance parts. I would even recommend a tune after bolt ons like headers.
bohmankid is offline   Reply With Quote
Old 07-21-2013, 11:28 PM   #4
BigRed76
BigRed76's Avatar
Yeah that makes sense. I don't need gobs of power, but figured a better cam would be very beneficial. Any recommendations on a cam that isn't too big for stock injectors?
Zach
Old 07-22-2013, 12:45 AM   #5
tinydb84
tinydb84's Avatar
Remember with a cam swap you may need new valve springs. Not a big deal but just something to consider
David
Instagram: myfabguy
Old 07-22-2013, 09:34 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
I'm using a Comp Cams LSr 265 cam, Lunati springs, 1.75" long tubes, K&N FIPK and a Blackbear Performance data log tune in my 5.3L with a Yank TT2600 converter. Stock injectors & intake. Good torquey DD setup. The valvetrain is a little noisier that stock, but the cam is over .600" lift with stout valvesprings, so that is to be expected.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-22-2013, 12:14 PM   #7
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Z06 cam is always a nice mild option. You can usually find a used one on LS1tech for cheap, or brand new they're on ebay or summit, etc for $300. you'll need the yellow beehive valve springs as well.
I'm running this cam with other upgrades and no dyno tune, yet, and it runs pretty strong.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-22-2013, 02:18 PM   #8
tinydb84
tinydb84's Avatar
I picked up a used Z06 cam for my 5.3. I havent gotten around to putting it in yet (engine is on the stand)
David
Instagram: myfabguy
Old 07-23-2013, 12:07 AM   #9
BigRed76
BigRed76's Avatar
I've read that the Z06 cam requires longer pushrods because of a smaller base circle on the cam. Is that correct?
Zach
Old 07-23-2013, 01:01 AM   #10
tinydb84
tinydb84's Avatar
Many people run the same ones. Its .050 smaller so your pushrod needs to be .025 shorter. I am planning to mill my heads .025 to bump the compression anyway.
David
Instagram: myfabguy
