Under hood liner?
Does anyone have any pics of custom under hood liners? I have the dynamat under the hood and want a bit of a cleaner look.
Older pic but you get the idea ![]() Posted via Mobile Device
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
Old member
I would like to see what people have done also. I've thought about doing this but would like to see some idea's on what to use and how to attach it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Under hood liner?
Anyone?
Same here. Would love to see how it's attached.
Here is another pic
definitely low cost here..This is foil insulation roll from Lowes attached w 3M speay adhesive. then cut with a utility knife. I could have done a better job if I'd used a sharper knife and been more careful, but it does work nicely--cuts down on the engine noise and the hood wiggle.
Figure out what you want--then figure out what you are willing to give up to get it. |
Yeah I already have the insulation in place, just looking for a liner or panel to make it look a bit better. Ie
