Designated A-hole!
Yet another dumb question!
How can you use the same speedometer regardless of rear end ratio, tranny type etc. Are sending units (on tranny) geared to correct for these things or what? Just something that crossed my mind.:p
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Your rear-end ratio will affect the reading big-time. If you're running 4:11 gears or lower, your speedo could say 75 when you're only doing 50! Tire size will affect this as well.
There is a gear in the transmission that runs the speed of the speedo cable. That gear an be changed.
gearing on the end of the speedo bolted into the trans via a steel cased cable on most of these trucks can be changed out for different gear ratio's. if and i mean IF you have a good GM Garage the parts guy will go out in the heat and muggiest of days and view your hotrod/truck/ or goofy project nad tell you a good idea of size and help get the right one for ya
http://www.lk3000.com/madura/pics/emblem_gold.jpg |
When I changed from 3.73 to 3.08 it made my speedometer
15 mph slow. I was already using 60 series tires and it was a little slow to begin with. I had an article that Hot Rod Magazine did on this problem and it was full of all the formulas and gears available. There are actually 2. They are ,or were, color coded. I figured out what I needed and went to the dealer. He had the cable gear and showed the inside gear. When he tried to order it, it came back as discontinued. There was a fellow who advertised in Hemmings that could build a unit to fix any of these problems. I ordered one of the units after giving him all the measurments he requested. The unit made the speedo 15 mph fast. I gave up out of frustration and decided to live with it. There are advantages to this. I know that when I am showing 55, I am actually doing 70. It is a cobweb in my truck and does bother me a little. I would like to hear what others have done. EdB |
krue, if you have an adaptor on the trans end of the cable, it will have the ratio stamped on it, that it is matched to. You will need to know the ratio of the gear set, and then get a matching adaptor for it. Much easier than changing the drive gear in the trans, which requires removal of the tail housing from the trans. Around here, the adaptors are available from speedo repair shops, or they sometimes change the gears in the existing adaptor to match the gear set, and tire diameter.
69 GMC K10 ..some restoration required....still.. ![]() Last edited by Class of 69; 07-01-2003 at 10:18 PM. |
Mike
Yeah what class of 69 said.Look in the yellow pages for a speedo shop.I use one in Lancaster Pa.I think they charged $75 to build a new ratio box for my big truck.When they where done it was off by less than 1 mph.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Getting cabin fever?!?!?!
forget those other speedometers. they make gps speedometers now! they work great apparently as long as you have a line of sight to 2 satellites. no matter what you do it's always right.
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
Life is Good !
There is a guy here in salinas, that changes the gears in the box that attaches to the transmission. I had him do the one for my '72 before I tore it apart. It had 33" tires 3.73 gears and stock 350/205, It was off by like 1 mph mabe 2. I will get his # if anyone is interested. It didn't cost $75.00 though, I think it was like $40 or something. but that was two or three years ago. I am going to be getting the one for jenna's 71 redone, mabe next month or so. After our camping trips, I am running 55 at 2000 rpm and i think it is off, so I am going to them to have them fix I'll let you guys know how much $$$ it is.
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
