07-20-2013, 10:30 PM | #1 |
67 Hood Installation HELP!!!
Need help with HOOD installation. My hood sits up at the cowl and then at the grill it does not fit well. I will post pictures shortly.
Is there a good method.
DREW67 |
07-20-2013, 11:58 PM | #2 | |
Re: 67 Hood Installation HELP!!!
Posted via Mobile Device |
07-21-2013, 12:06 AM | #3 |
If I remember I take a permanent marker and trace along the outside of the hinges before I remove or loosen anything. It makes things easier when reassembling.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
07-21-2013, 09:31 AM | #4 |
worn out hood hinges with alot of slop allows hood to pop up at the cowl many times// that cant b adjusted out
07-21-2013, 09:48 AM | #5 |
^ x2 check the rivets on the hinges
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
07-21-2013, 10:03 AM | #6 |
Aligning body parts is not an exact science but most will agree it can be a PITA
07-21-2013, 09:30 PM | #7 |
Thanks all I will try it out.
DREW67 |
07-21-2013, 09:39 PM | #8 |
Make sure the hood isn't tearing apart from the bolt holes either. Mine did that and I just welded them up did a little grinding and some repaint and Ta Da! Presto!. I also did use a marker before I took the hood off and it went right back into place. Good luck.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
07-21-2013, 09:48 PM | #9 |
Rusty Nuts
If I am not mistaken, if the hood is too high in the back you need the back of the hinge go down and the front of the hinge come up. Or you might not need to adjust the front of the hinge at all.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
07-21-2013, 10:24 PM | #10 |
I had to have someone push downward and towards the rear on the hood while it was upright.. sounds weird.. and then tighten the bolts. you may be able to see where the old washers were at. helps get it close anyway.
07-21-2013, 10:32 PM | #11 |
The Older Generation
Here's the procedure posted by Huck: To get the back down with existing hinges---open hood----loosen the three bolts that attach hinge to fender (both sides). Now push the hood up till the hinges stop moving, ---now push it open a bit more to preload the hinges. Tighten hinges. (two people make it a lot easier) now CAREFULLY lower the hood--this may take a few adjustments to get it to sit just right (height wise). You may need to adjust the hood front to rear to allow for proper clearance with the cowl. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-21-2013 at 11:30 PM. |
07-21-2013, 10:33 PM | #12 |
Double post for some reason... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-21-2013 at 11:28 PM. |
07-21-2013, 11:07 PM | #13 |
I'll grab Rick some evening and we will come buy and help you. Just let me know when
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
07-22-2013, 08:19 AM | #14 |
It would be a honor to have you guys over.
DREW67 |
07-22-2013, 09:14 AM | #15 |
Text me and let me know a night that works for you
07-22-2013, 09:56 AM | #16 |
generally when the hood is high in the back , the hinges are worn , and you need new hinges
