Old 07-21-2013, 08:06 AM   #1
Neatbeard
Neatbeard's Avatar
What Oil for an old inline 6?
Hi folks I did a search but there were soooooo many threads to wade through I hoped that i'd get a quicker answer here.
Bearing in mind i'm in the UK, what oil should I be running in my old inline 6 250 Hi Torque?
Also what quantity should it take if i did an oil change?
Thanks in advance.
My old truck:
'66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701
Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk
Neatbeard is offline   Reply With Quote
Old 07-21-2013, 08:16 AM   #2
Sharps40
Re: What Oil for an old inline 6?
My 65 owners manual calls for 10W30. The 230 I have is rebuilt so I run 4.5 quarts of 10W30 and a 1/2 quart of ZDDP additave with filter change at each oil change. If the motor is a bit worn, ya can also run 10W40 if it ain't too cold.
Sharps40 is offline   Reply With Quote
Old 07-21-2013, 08:47 PM   #3
KroAutomotiveInc
KroAutomotiveInc's Avatar
I use 15-40w fleet-line oil in my 230 does wonders for these old things mine has 130k on it. It also helps quit lifters if there noisey. I also live in utah and have never had a problem with the thick oil during the winter. I also run 17-20 mpg. Good luck!
KroAutomotiveInc is offline   Reply With Quote
Old 07-21-2013, 10:20 PM   #4
Vernski
Multi weight oil is for a wider tempeture range I would say somewhere in the middle like 20w-40 but remember the modern oil has no ZDDP in it so you will have to add some to it. They are selling oil now with the zinc in it for the older vehicles but not everywhere. Use what the owners manual indicates hot-thicker colder-thinner, what climate you live in decides the weight. Brands don't matter it all comes from the same refinery or hole in the ground, just change it at mfg. indicated intervals and you will be fine..Vernski
Vernski is offline   Reply With Quote
Old 07-22-2013, 05:16 AM   #5
Neatbeard
Neatbeard's Avatar
Thanks for the replies folks.
My old truck:
