Old 07-21-2013, 10:40 AM   #1
Ricks1971
Ricks1971's Avatar
67 drum to 72 disc brakes?
I have a 67 chevy C10 with drum brakes and power assist setup. It has a power boost brake cylinder. I have a 72 C10 that I am taking the disc brakes of of. My question is will I have to change the brake cylinder also even though both truck have the power boost setup?
Ricks1971 is offline   Reply With Quote
Old 07-21-2013, 11:38 AM   #2
cdowns
cdowns's Avatar
Re: 67 drum to 72 disc brakes?
brake cylinders on each rear wheel can b used with the disc brake conversion
the master cylinder that mounts on the firewall however can not b reused frome the drum to disc conversion plus you will need a combination valve from 71 plus new different sized brake lines
Old 07-21-2013, 09:50 PM   #3
Ricks1971
Ricks1971's Avatar
cdowns, here are the 2 power boosters one a 67 and the other a 72. Do I have to replace all the brake lines? Thought it was a easy conversion
Old 07-23-2013, 10:56 AM   #4
BlackZ
New Member
The 72 master is needed to run the front disc setup, as well as the proportioning valve. Swap the boosters too, the adjusting rods are different for the different cylinders, if I recall. You will need to change the front brake line from the master to the tee block for the front brakes, and change the rear line fitting using a new brake line nut that is the correct size. (You should be able to attain the line and the different size brake nuts you need from your local parts house, or just use your lines off the 72, if they're any good.) You will also need to use the Tie rods, adjusting sleeves, and centerlink from the 72 as well. You also need to swap controls arms too since the balljoints and steering stops are different. If you have a complete donor truck, just use all the 72 stuff and you should be good.
70 GMC C10
70 Chevrolet C10
69 Chevrolet Custom/10
68 Chevrolet K10
67 Chevrolet K10
BlackZ is offline   Reply With Quote
