Old 07-21-2013, 10:52 AM   #1
Jon01
Jon01's Avatar
Sway Bars - what fits, what doesn't?
Apparently my 71 doesn't have either a front or rear bar.
This makes for some interesting driving dynamics at highway speeds
I was leaning towards the CPP f/r setup as it's inexpensive and looks like it would work well.
However I've read of people having interference issues on lowered trucks, especially when they run a rack conversion which I could see doing in the future.
I don't plan on doing anything drastic with mine beyond the 5.5/6 drop I have in the garage for it but I sure don't want to be stuck with parts that don't fit.
So, what are you guys running on your rides for sway bars and how happy are you with the fit/function?
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 07-21-2013, 11:58 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Sway Bars - what fits, what doesn't?
Stock one tons fit great like they were almost made too lol
But seriously none of the aftermarket ones I've seen fit as good as oem
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-22-2013, 08:58 AM   #3
Jon01
Jon01's Avatar
Fair enough!
What year tonners do you get them off of?
Old 07-22-2013, 09:45 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Any square body truck. Basically any 73-87, but they did make 1 tons and Suburbans in the old body style up through 91.
Old 07-23-2013, 09:58 AM   #5
Jon01
Jon01's Avatar
Cool - thanks man!
Old 07-24-2013, 12:04 PM   #6
robnolimit
robnolimit's Avatar
Take a look at our No Limit C10 bars. Both the front and rear offer several improvements over the OE style. They may not be as cheap as other brands, but then again, there not as 'cheap'.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 07-31-2013, 12:50 PM   #7
oldno7
oldno7's Avatar
I would like to seen some install pics i picked one up from porterbuilt and still havnt installed it, i guess im stupid but i like being pos its correct and tend to overthink things. Im thinking you have to drill out a hole in the frame but not sure truck has a 4/6 drop
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 08-02-2013, 10:41 PM   #8
sduckworth13
sduckworth13's Avatar
Found this today while looking for rear sway bar options for my truck
http://www.low69cst.freeservers.com/CamaroBar.htm
Scott
sduckworth13 is offline   Reply With Quote
Old 08-04-2013, 09:35 AM   #9
wraprail
wraprail's Avatar
Change the end links to rod ends and forget all that spacer crap. If the bar needs a little tweek to fit right, use a very hot torch. Done it without issue. It's only metal.
wraprail is offline   Reply With Quote
