Old 07-21-2013, 12:51 PM   #1
Midgets50
Midgets50's Avatar
brake lines help
ok so im to running brake lines but ive ran into a snag. i need a longer brake line that goes from frame to caliper. would it be possible to use hydraulic hose lines instead of trying to find longer rubber brake lines?
Thanks for the help in advance
Midgets50 is offline   Reply With Quote
Old 07-21-2013, 07:00 PM   #2
OrrieG
OrrieG's Avatar
Re: brake lines help
Give Russell a call, I had the same issue and just told them what I had and the guy over the phone told me the numbers to order. Got braided three (calipers and one rear) braided stainless and self bleeders from summitt for $120 including shipping. If you use rubber make sure the hose is rated for brake fluid and pressure. I got braided because I will be using the truck and the old rubber ones did show signs of abuse from tree limbs, etc.
OrrieG is offline   Reply With Quote
Old 07-21-2013, 08:08 PM   #3
Midgets50
Midgets50's Avatar
i might have to do that. how do i find out what pressure brake lines are rated for because i can get heavy duty hydraulic hoses made for me at a reasonable price. the 1/4 lines i can get are rated at 6000 PSI. is that enough??
Old 07-21-2013, 10:03 PM   #4
mknittle
mknittle's Avatar
how about these? they work great on my jeep.
http://inlinetube.com/Brake%20Hoses%...ss/sshoses.htm
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-21-2013, 10:05 PM   #5
mknittle
mknittle's Avatar
vacuum boosters put out around 1500#s and hydroboost over 2000#s
Mark
My GMC build.
Old 07-21-2013, 10:19 PM   #6
Midgets50
Midgets50's Avatar
thanks guys. ill have to do some measuring and then see about ordering me some new lines so i can get one step closer to driving it
