Old 07-21-2013, 12:53 PM   #1
Midgets50
Midgets50's Avatar
brake lines help
ok so im to running brake lines but ive ran into a snag. i need a longer brake line that goes from frame to caliper. would it be possible to use hydraulic hose lines instead of trying to find longer rubber brake lines?
Thanks for the help in advance
Midgets50 is offline   Reply With Quote
Old 07-21-2013, 01:01 PM   #2
mknittle
mknittle's Avatar
Re: brake lines help
We use the beaded lines on lifted trucks. I like the pedal feel way better than rubber spongy lines.
http://inlinetube.com/Brake%20Hoses%...ss/sshoses.htm
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-21-2013, 06:39 PM   #3
lazypineapple
lazypineapple's Avatar
The larger the hose or line the softer or mushy the pedal will feel = crappy brakes = unsafe.
Making SS hose is easy. Just buy extra furrels that's the only part that isn't reusable. If you screw up and they leak at the hose connecting to the fitting.
lazypineapple is offline   Reply With Quote
