Old 07-21-2013, 03:10 PM   #1
Jfarns03
Jfarns03's Avatar
What are the three fuel lines for the 5.3L
For my 5.3L swap i noticed i have three fuel lines connected all around the engine and i dont know which is which. Pic are helpful!
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 07-21-2013, 03:40 PM   #2
mmiddle
mmiddle's Avatar
Re: What are the three fuel lines for the 5.3L
The big one is the fuel supply goes to the fuel rail.
The next one is the fuel return goes to the FPR on the fuel rail.
The other is the purge vacuum line going to the purge valve on top front of the upper plenum.
Sorry, no pics from me.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-21-2013, 03:46 PM   #3
Jfarns03
Jfarns03's Avatar
where do i hook up the vacuum line too? Thanks for the response!
Old 07-21-2013, 04:20 PM   #4
mmiddle
mmiddle's Avatar
It goes to the fuel tank purge charcoal canister that is originally mounted in front of the tank. If you are not using the canister then it can be eliminated. However the purge sequence must be edited in the ECM or you will get codes
Mark
Jesus is the Way!
Old 07-21-2013, 06:42 PM   #5
eagleuh1
eagleuh1's Avatar
Put a vacuum plug over it and delete on your PCM when you have it tuned, as stated above.
eagleuh1 is offline   Reply With Quote
Old 07-21-2013, 06:52 PM   #6
Jfarns03
Jfarns03's Avatar
perfect thank you guys! im inching closer to getting this thing running!
Old 07-21-2013, 10:21 PM   #7
88Ironduke
I used that port on another project to provide vacume for power brakes. The motor didn't have a vacume port for the booster so it made sense to re-purpose the existing port.
88
88Ironduke is offline   Reply With Quote
Old 07-21-2013, 11:10 PM   #8
mmiddle
mmiddle's Avatar
Truthfully, I'm thinking about using the Evap canister. I have it from the '99 parts truck I had. I'm still unclear on what I want to do with the fuel tank/supply system.
Mark
Jesus is the Way!
Old 07-24-2013, 10:35 PM   #9
Jfarns03
Jfarns03's Avatar
if i cap it off will it effect the performance of the truck?
