Old 07-21-2013, 08:49 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
P/S Pulley ?
RE: My on-going serpentine upgrade - Is the P/S pulley pressed on or shrink-fitted? There seems to be no keyway or means of holding it on. How much heat is required to get one on? Or is there some other trick I'm not aware of?
TobyArnot is offline   Reply With Quote
Old 07-21-2013, 09:11 PM   #2
68shortfleet
Re: P/S Pulley ?
NO HEAT..they are pressed on. They also require a specific puller to get them on and off. You can't just put the in a shop press.
68shortfleet is offline   Reply With Quote
Old 07-21-2013, 10:05 PM   #3
Lee H
Lee H's Avatar
Re: P/S Pulley ?
Your local auto parts box store will have the correct puller for rent. Apply heat and buy a new pump your choice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 07-22-2013, 05:14 AM   #4
TobyArnot
TobyArnot's Avatar
Re: P/S Pulley ?
Mine is off, just looking to install it. I'll check on the rental tool tomorrow. Thought about heating the "off" pulley enought to get it to "drop" on. But, thanks to all for the input.
