Old 07-01-2003, 11:26 PM   #1
cnshoot
cnshoot's Avatar
12 bolt pinion yoke
i had just went thru this and if anyone needs this you can find your 10 bolt pinion yoke is bigger and use a jump joint and the seal # is 8622 carquest i hope this may help someone and if you want to go a step further you can change to a newer diveshaft and use the jump joint in front
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 07-05-2003, 11:08 AM   #2
cnshoot
cnshoot's Avatar
hope that it helps it is working great i love it
