Is this fitting really necessary???
I'm guessing it is there to make removing/installing the instrument cluster easier? Is anyone running a solid line with no breakes in it? It's not very long, seems like it would be just as easy to disconnect it at the motor.
What is the real reason for this connector? |
Re: Is this fitting really necessary???
Comes in handy when pulling the motor...but you can just unhook it from the block too.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
i always have just removed the oil line from the back of the gauge when removing my clusters
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I agree, it's just easier not having to fish through the firewall
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
It's most likely there for assembly line purposes, one line coming off the engine and one line coming out of the cab, after the cab is put on, just connected the two.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Aug 2008
I am running a one piece line now that i got from Brothers. The body shop misplaced the original two piece one when they painted the truck (dont ask).
Posted via Mobile Device |
Scrapper 1
OK i have to say this cus you left the door open.Lets say you live on a 1 archer lot and your water main is about 2000 feet away with the main shut off valve would you install a shut off valve closer to the house!!!
I owed over 20 of these trucks most of them are from 1960--66 and trust me you want as many places in wire harness or copper lines to have brakes in them Had a 1964 short bed some one took out the copper line and ran a steel 1 line to the gauge well I burn that truck to the ground. I bought it for 700.00 and i drove it for 2 months one of the engine motor mounts was broken on the driver side I guess the PO did not like the copper line with the connector in the middle so he replaced it with a solid one that was so ridged any moment of the cab or the engine well when it broke it sprayed all of the engine bay and lite. You ever put out a Oil fire there not fun wish i have a shelve. I think i had enough time to open the hood and get at least 3 to 4 thows of dirt before i would of lost the hole truck. I glad your asking questions I'm not fond of newbies working on these truck or any thing that deals with oil and gas.But do your home work GM really made it easy on us working man to maintain there old car's and trucks with short cuts like that copper line |
#8 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Otherwise they'd have had to keep several different oil lines on hand depending on which engine the truck received and snake it in afterward. |
#9 | |
#10 | |
