Senoir Member
67-72 cabs
Are all 67-72 cabs with A/C the same? I have a 70 GMC with a factory big block and want to add A/C, what years will interchange correctly. Thanks.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
69 and 70 will work with no effort at all, the rest will require some minor changes.
CCRider
I think this is correct but someone will speak up if it is not. 67-68 have hand operated park brake. 71-72 have cable operated linkage to the carb and 72 has no mount for the rearveiw mirrow, so I think only 69-70 would interchange "correctly" You could save a bunch of money and have better air by just adding a Vintage Air or Old Air set up.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Plus the 71-72 have the different fuel tank system.
Senoir Member
Thanks for the info, Vintage air maybe the best route. Greg
