I've heard that Dakota or Durango door seals work, is this true? Any other cars or trucks I should look for. I have a 72 gmc. Thanks for the help guys.
1972 GMC LWB ![]() |
Re: What door seals from other vehicles fit our trucks?
I used the slip on from gmc pauls, think they were dakota and they do fine.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
#3 | |
Posted via Mobile Device |
bbadfred
![]() Join Date: Mar 2008
GMC Pauls are easy to install (the hardest part is cleaning off the old glue) they fit nice and seal very well. They come in a roll with a little extra and are not pre formed
#5 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
bbadfred
The Older Generation
Dodge makes the best ones... '87-'97 Dodge Dakota, pick 'em up at your local salvage yard. You can find some nice ones for 5-10 bucks per pair. The nice thing is they are slip fit, you don't have to glue them on. Be sure to get the connector that joins them at the seam. Sometimes it falls out when you remove them. All you need to remove them is a phillips screwdriver, small hammer, and a small prybar. You have to cut about 3" off the length... LockDoc
Thanks for the info, I think I'll try the dodge ones first, just to save some money, and if they dont work ill just order from GMCpaul. thanks.
I grabbed mine out of a 200x model Silverado. Tahoe and gmc models will be the same. Had about ten inches to cut off. Just measure the perimeter of your door seal area and then measure the one you find in the junk yard if you want to be sure. It just pulls off and presses on. That simple
![]() Join Date: Feb 2001
Great info
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
got mine from a dakota for 10 bucks, they work fine
72 Cheyenne LWB |
Tags |
door seals, other vehicles, weather striping |
