Old 07-22-2013, 03:10 PM   #1
Northern cali chevys
turbo 350 vs. 200r4
Hello everyone, its been roughly a year since I was on the forum last due to purchasing my first home and having to put aside my 68 stepside project. I am finally back on it. I have a zz4 crate engine in it and a buddy of mine gave me his built 200r4. Originally I was going to go with a turbo 350 but since the 200 has an extra gear I am considering it instead but I just dont know how the fitment would be. Anyone have any input? Thanks.
Northern cali chevys is offline   Reply With Quote
Old 07-22-2013, 03:58 PM   #2
cdowns
cdowns's Avatar
Re: turbo 350 vs. 200r4
first learn that the tranny is a 200 4R
it is pretty mucha direct replacement for a turbo 350 that has the short 6"tailshaft
Old 07-22-2013, 04:34 PM   #3
Cdowns thanks for the reply. It is definitely a 200 4r. So drive shaft and crossmembers are not going to need any modification?
Old 07-22-2013, 04:42 PM   #4
cdowns
cdowns's Avatar
no shaft or crossmember mods needed for a short tailshaft 350 // the one tricky thing is getting the TVcable setup correctly for a long tranny life
Old 07-22-2013, 04:51 PM   #5
Perfect. I may have to take it to a tranny shop for that because I've burnt up 2 700s on my iroc from the tv cable not being properly adjusted. Unless I can get a good step by step how to on here from someone.
Old 07-22-2013, 05:35 PM   #6
geezer#99
geezer#99's Avatar
Look here for info for your TV cable set up.
http://www.bowtieoverdrives.com/index.shtml
geezer#99 is online now   Reply With Quote
Old 07-22-2013, 05:54 PM   #7
Thanks geezer#99. There's good info on that link.
Anyone think I should stick with the th350 aposed to the 200? I plan on using the truck as an everyday driver with the occasional track meets.
Old 07-22-2013, 08:59 PM   #8
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I think you should stick with the TH350 and I'll just take the 200 4R off your hands.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-23-2013, 10:35 AM   #9
Haha never hurts to try Derotoreut .
Old 07-23-2013, 10:37 AM   #10
Anyone know if a 69 chevy van tilt column would work in my 68? Would it need shortening or any other mods? I found one pretty cheap I just don't want to waste my time making the hour n a half drive for nothing.
Old 07-24-2013, 02:08 AM   #11
BlackedOut67shorty
BlackedOut67shorty's Avatar
van columns are a good amount shorter, you will need the intermidiate shaft to be lengthend, they usually have plastic rivits you can melt to extend them out. The column will be tight but it can be done, did it with my 67
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 07-24-2013, 10:03 AM   #12
kaycee
kaycee's Avatar
Just swapped in a 4L60 in place of the TH-350 last winter after f@##$%^ with the cable and brackets I ponyed up and bought the Bowtie tv made easykit.No problems so far and wished I would of switched them years/miles ago
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 07-24-2013, 11:15 AM   #13
Kaycee where can I get that tv cable made easy from. Nobody likes to struggle.lol
