07-22-2013, 04:02 PM | #1 |
Body swap questions '89 to '82
I am getting ready to start pushing forward on a body swap on my very rusty '82 2wd K5, complete front clip and all.
I have an '89 GMC Jimmy that is rust free (motor shot, hasn't ran in maybe 10 years). Looking for advice and things I might need to watch out for. I intended to use the harness's from the '89, but what problems could I run into with that? The '82 has AC, and really nothing else; the '89 is fully loaded. '89 is TBI, but I will be running a carb'd engine (maybe TBI later, or maybe 6.0l further down the line). I will probably keep the low-hump from my '82 body and cut out the floor around it (bolt-in hump, '89 hump is not removeable), but one reason I would do that is I have a brand new low hump carpet kit. On the '89 the floor is cracked around the seat mounts so I need to do some floor work anyways. Any other considerations I should take on doing this swap? Any thing I should keep off the '89 chassis that I will need later down the line to finish swap; I want to take the chassis directly to the scrapper? Thanks in advance!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
07-22-2013, 04:15 PM | #2 |
Re: Body swap questions '89 to '82
you would be a lot better off putting a engine in the 89 Totally different frame and body
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
07-22-2013, 04:24 PM | #3 |
The '89 is a 4x4 and the '82 is 2-wheel drive; I want to keep the 2-wheel drive. '82 is the last year for the 2-wheel drive.
Body (tub) is the same, only thing different is the core support and headlight set-up. Fuse block is different so harnesses are different which is why I would keep those. Doors, fenders, tailgate, etc are all the same as far as I know. Maybe I am not understanding what you are referring to?
07-22-2013, 04:27 PM | #4 |
my mistake thought you were working on a truck They are different
07-23-2013, 06:34 PM | #5 |
Maybe I should have put K5 in the title
So no one else, this a pretty straight forward deal?
07-23-2013, 06:49 PM | #6 |
Slots go on anything!
The only frame change I know of was between 77 and 78, when the rear floor changed. Just me, but I would leave the high hump and buy a new carpet.
1974 Jimmy- 5.3/4L80e/NP241 |
07-23-2013, 10:31 PM | #7 | |
I am not a welder, so that decision might come down to how much I will get charged to do the additional work?
