Old 07-22-2013, 08:59 PM   #1
czarcaustic
czarcaustic's Avatar
I think I broke my truck ...
Hey guys. I had to really pour on the throttle the other day in a situation on the road, after slowing back down to normal cruising speed I noticed a new noise from under the hood. It was almost a ticking or scraping sound that increased and decreased w/ RPM.
I have attached a crappy (dark and iphone) video to hear the sound. I have also noticed white smoke out of the tailpipes now ... which was never an issue.
Any suggestions as to what I may have done? I can't tell any real difference in power ... but the noise and smoke are definitely new.
Old engine sound no smoke:
New engine sound w/ smoke (loud - turn speakers down):
'71 GMC 1500 Longbed (Marilyn: PICS)
'04 Toyota Tacoma (grocery getter)
'03 Lexus ES 300 (Wife's)
'72 GMC Short Fleet (Sold - offer I couldn't refuse)
czarcaustic is offline   Reply With Quote
Old 07-22-2013, 09:19 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: I think I broke my truck ...
Hard to comment on the videos. I'd yank the valve covers first and check out whats happening under them.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 07-22-2013, 09:24 PM   #3
rogergodding
rogergodding's Avatar
Yeah, pull the covers and check those rockers.... I had a great sounding engine with a lopey cam several years ago.... got on the throttle and one of my lifters seized up, inside the block, shaved my cam down a bit.... shortly thereafter was a knock coming from the crank......
rogergodding is offline   Reply With Quote
Old 07-22-2013, 10:25 PM   #4
70cst
70cst's Avatar
Good luck. Hope it isn't serious
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-22-2013, 11:19 PM   #5
IntegratedTJ
IntegratedTJ's Avatar
From my experience, a blown head gasket could be the culprit. Also could be worn out rings but I'm not sure it'd come out of nowhere all at once. But as the others said, check what's easy to check first. Good luck. Post back with results, would be good to know for possible future situations.
Edit: Just watched the video, that sound is pretty nasty. Hope all is well. Doesn't seem like any of the two things I suggested. Hope it works out well, man.
IntegratedTJ is offline   Reply With Quote
Old 07-23-2013, 01:04 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
You have a very nice truck. I cant help you with your noise problem but will say what ever it is it's worth fixing. By the way your rims look super.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-23-2013, 01:52 AM   #7
leddzepp
Moderator
leddzepp's Avatar
With the white smoke I'd say a blown head gasket. Check your radiator to see if the level has dropped. Sounds like a scraping noise as opposed to a knock, as suggested above pull the valve covers and check things out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 07-23-2013, 12:25 PM   #8
czarcaustic
Thanks for the responses everyone. I don't have much time to tear into the engine this week ... so it looks like Marilyn will need to sit under the carport until I can get to her this weekend. I cranked her up again last night, to see if I could better diagnose the location of the noise and it sounds even worse/louder. I don't want to fire it up again until I can locate the issue.
Bummer. Ruined my pretty decent week.
I will keep everyone updated.
Old 07-23-2013, 12:46 PM   #9
czarcaustic
Neighbor talked me into starting it up one more time so he could hear it. He is of the opinion that it isn't internal (not a knock or ping as he said). He thinks it is likely a pulley bearing, hence the 'scrape' sound. The white smoke is something he didn't seem too concerned about with an engine this old ... since it isn't "pouring out or anything - obviously you should fix whatever is causing it, but I don't think it is necessarily related to the noise".
He knows more than I do about engines. Does that sound plausible?
Old 07-23-2013, 01:11 PM   #10
cleszkie
cleszkie's Avatar
Not to piss on what your neighbor told you, but if that white smoke just suddenly appeared, then you just suddenly got a leak in your water system, and that needs attention. As others have said, could be a head gasket which will rapidly get worse, or it could be something worse like a cracked head or block. Check your oil to see if you have water in it before you run it again. Good luck.
cleszkie is offline   Reply With Quote
Old 07-23-2013, 01:21 PM   #11
czarcaustic
No no - I understand. I know you aren't pissing on the neighbor. I am all about differences of opinion so that I know how to diagnose and potentially fix this issue. All information, properly filtered, is good information (if not now, then possibly later.)
I agree that the smoke is something that needs to be addressed.
Old 07-23-2013, 01:35 PM   #12
mmiddle
mmiddle's Avatar
Yes, I think the scraping sound is external. The smoke could be bad valve seals that where wiped out under high WOT vacuum. It is hard to say by just a discription of the events and a low quality video.
I would pull the belts off and closely check all pulleys and bearings AND the crank balancer and pulley. It could also be the input bearing on the trans.
the smoke is a nucence but only tell-tells a tired motor that needs refreshed at some point in the future.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-23-2013, 01:37 PM   #13
mmiddle
mmiddle's Avatar
And yes, you do need to confirm that this smoke is oil or coolant. Oil = tired motor. Coolant = head gasket or crack that needs fixed now.
Mark
Jesus is the Way!
Old 07-23-2013, 01:50 PM   #14
Bigdav160
Bigdav160's Avatar
The noise sounds like the compressor clutch.
The "smoke" could be normal water vapor from combustion.
Does it get worse as the engine warms up or goes away?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-23-2013, 01:53 PM   #15
czarcaustic
Again - thanks for all of the suggestions guys. I will jump into a full-on diagnosis this weekend and report back.
Lunch is over and it is now time to head back to my day job. LAME!
Old 07-23-2013, 02:08 PM   #16
chevyman95
chevyman95's Avatar
Easy way to tell if it is a pulley is take off the belts and crank it up for a few seconds and see if the sound is still there. I've never done this with one of these trucks but it helped me isolate a noise on my 04 GTO. Don't run it more than a few seconds though because you don't want to overheat the truck
chevyman95 is offline   Reply With Quote
Old 07-23-2013, 02:54 PM   #17
Coley
Coley's Avatar
Smile Re: I think I broke my truck ...
I'm kinda' with BigDave on this one....with respect to the compressor clutch.
Start by disconnecting the a/c belt and see if it continues.
After that disconnect all the belts one at a time....and re-check the engine for sounds when running. Be careful not to overheat the truck with the water pump disconnected.
If it is the a/c compressor-clutch or the water pump or the alternator...removing the belt from that accessory will quickly identify the problem.
Put a timing light on it to see if you have an extremely 'scattered' timing signal....ie: if your timing chain was extremely loose, rubbing and possibly going to let go...it would probably show up with the timing light.
Also, check both your oil and radiator to see if they still look uncontaminated from either liquid...this would be a possible sign of a blown head gasket or a coolant/passage failure or similar.
Good Luck, keep us posted.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
