07-22-2013, 10:56 PM | #1 |
GM ONLY BABY!!!
Got my a/c working but have ???
I have a 01 6.0 dbc with the Sanden 508 comp., Dirty Dingo bracket, new American Autowire harness, and Old Air Products POA update kit, new receiver/dryer. All new orings oiled up too. Had it vacced and pressure checked, charged with 1lb 10oz. of R134 and 3 oz of low viscosity pag oil and dye installed. It blows somewhat cold but not as cold as I'd like it to. Any suggestions?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
07-22-2013, 11:07 PM | #2 |
Re: Got my a/c working but have ???
What are the pressures when using a set of ac gauges? Low side should be between 35-45 on low and 150-250 on high side. Sounds like you dont have enough freon. Also are you running a r134 condesor or the r12 one.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-22-2013, 11:09 PM | #3 |
GM ONLY BABY!!!
Yes, I have a R134 condensor. Low pressure side was at 48-49 psi. I don't remember what high side was.
07-22-2013, 11:15 PM | #4 |
Sounds like its over charged then. R134 wont cool if over charged either
07-22-2013, 11:21 PM | #5 |
How big is the condenser? Do you have good airflow going through it (and not around it)? Is the compressor cycling?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-22-2013, 11:21 PM | #6 |
GM ONLY BABY!!!
I was thinking maybe over or undercharged. Would overcharged be a higher pressure and under be a lower pressure?
07-22-2013, 11:24 PM | #7 |
GM ONLY BABY!!!
The condensor is the stock replacement for the truck, it's about 5 years old. A/c was functioning 4 years ago when I had a sbc and Sanden comp. in it. The compressor is not cycling. I have the stock fan shroud for the truck and am using the 6.0 clutch fan, it's a tight fit.
07-23-2013, 07:07 AM | #8 |
I mean its a toss up not enough air flow will jack the head pressures up causeing it not to cool get you a good strong box fan and sit it in f ront of the rad and condenser and see if that helps thats what we do at work to check an air flow problem
07-23-2013, 10:06 AM | #9 |
GM ONLY BABY!!!
Cruising at 40-50 mph helped a little but my friend that vacced and charged it said he normally sees around 50 psi on low side on the newer stuff.
07-23-2013, 11:42 AM | #10 |
I would lower pull some of the refrigerant out. put a thermometer in the vent and slowly add more until temps get to around 40 degrees. My system needed about 2 and a half 12 ounce cans. It was all custom a/c system.
07-23-2013, 10:46 PM | #11 |
I used all the factory components in my ls swap except the compressor and lines, i recharged it with the factory recommended amount and it blows ice cold. Wanting to say the pressure was close to 50 on the low side also. I spoke to an ac guy and he told me that with the 100* days we see here in tx, it is normal to see around 50 lbs on the low side.. hope this helps
07-23-2013, 11:12 PM | #12 | |
GM ONLY BABY!!!
07-25-2013, 08:08 PM | #13 |
Same problem I'm having with a sd7 compressor. I'm getting about 55 degree vent temps cursing around . It's hot and humid around here also.
Posted via Mobile Device |
07-25-2013, 09:00 PM | #14 |
GM ONLY BABY!!!
I found a small leak between the 2 nuts on the expansion valve. Is there a o ring in there? Also I think I need to bend up some aluminium to duct the air better between the condensor and radiator.
07-25-2013, 11:20 PM | #15 |
I put 2.75 lbs in mine or about 3.5 cans.
07-29-2013, 03:50 PM | #16 |
17's too small
You need to know the low and high side pressures to really know if it is over or under charged. Also the pressure varies a lot depending upon ambient temp. I cant get to google images, the dang work server blocks it, otherwise I would post a chart for you.
Also, if you are using factory specs for the freon amount you need to use 80% of that for 134, generally speaking. That should get you close on most conversions.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
