Inner fender install questions.
When I bought my truck the inner fenders came with it, in the bed. I cleaned them up, bought a bolt kit and went to it. The passenger side seems to fit okay but the drivers side doesn't even seem close. It hits on the steering shaft pretty bad and I don't know where the frame side of the inner fender bolts to. Does anyone have any tips or pictures of how the inner fender fits around the steering shaft?
Thanks! Posted via Mobile Device |
![]() Join Date: Mar 2000
Re: Inner fender install questions.
I don't have pic's but the frame side bolts to the frame where it curves downward. If your having a problem with the inner hitting on the steering you should probably look at your radiator support & cab mounts. When they go bad they allow everything ( front clip & cab sheet metal ) to sag which then places the inner fender in contact with the steering shaft.
Paul @ GMCPauls |
The Older Generation
There is a separate piece of metal that bolts to the holes in the inner panel to the right side of the shaft. It is about 1 1/2 inches wide and about 12 inches long with a bolt hole in each end. LockDoc
#4 | |
member #16
![]() Join Date: Dec 1999
Here's a pic that shows that piece.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Perfect, that's just what I needed.Thanks!
