Antiseize on a temp sensor?
I have a brass temp sensor going into my intake, The PO had wrapped teflon tape on it before but I removed it. Should I use a little antiseize on the threads?
Re: Antiseize on a temp sensor?
You shouldn't need anything on brass threads to seal or prevent corrosion. However, since it is in a water jacket, I would use some non-hardening teflon paste to gaurantee no leaks. I use it on all of my bolts that penetrate either a water jacket or oil gallery. You can get it at any auto parts store next to the silicon gasket sealers.
![]() Join Date: Jul 2013
2x
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
The Older Generation
Your temp gauge may not work correctly if you put any sealant on it . It has to have a ground through the threads for the gauge to work.... I would put some on the bolt threads though. LockDoc
