Old 07-23-2013, 04:18 PM   #1
Straight six
Straight six's Avatar
78 heavy half ton
So I was finally able to track down more info on my c15. The paper work says its a heavy half ton. So I'm wondering if I can use 1/2 and 3/4 ton front and rear suspension shocks, leaf springs, ect. I think it's got 8 leafs in rear really would like to use the 4 or 6 leafs there a little cheaper and if all of it would be a bolt in installation. And now I'm wondering what the other differences would be if any or does it just mean the suspension is different?
Straight six is offline   Reply With Quote
Old 07-23-2013, 04:47 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: 78 heavy half ton
The heavy duty rear leafs were 56" long. Standard leafs are 52". Your rear hangars will be in the wrong location if you try to install regular duty leafs.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 07-23-2013, 05:32 PM   #3
Straight six
So could I move the position of the hangers? and is that a something that could be done with drilling a couple more holes and sliding them in more
Old 07-23-2013, 06:56 PM   #4
Prerunner1982
Prerunner1982's Avatar
The wholes should already be in the frame. You will have to cut/drill out the factory rivets for the shackle mounts to move them back. Use grade 8 bolts when re-installing the mounts further back.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-23-2013, 07:20 PM   #5
LONGHAIR
Essentially the "heavy half" trucks are a 3/4 ton truck with 5 lug wheels.
They have the heavier springs and bigger brakes, just not 8 lug axles/rotors
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-23-2013, 10:06 PM   #6
Straight six
Thanks, sounds like a fun little project ill definitely start Friday night. I don't tow or haul any big loads so I think the 4 leaf will work great well I hope lol. Would you think it's a good idea to replace the shackles or keep originals and just clean up
Old 07-23-2013, 10:27 PM   #7
manimal
manimal's Avatar
not quite....The frame is still a 1/2t frame. Just went through this.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-23-2013, 10:33 PM   #8
Straight six
What are you talking about the 4 leafs are 1/2 ton so I'm putting them on a 1/2 ton frame I don't see the issue with that
Old 07-23-2013, 10:36 PM   #9
manimal
manimal's Avatar
The response was not meant for you,sorry. You have the right plan.
-Lance
Old 07-23-2013, 10:49 PM   #10
Straight six
Ok thanks then Friday it is . Sorry for the snap
Old 07-24-2013, 01:29 AM   #11
THE "10" SILVERADO
Yeah, the large springs suck butt ride wise. I've got them on my 77. I would put 4 leaf packs in but I'm too lazy to mess with the rivets.
Michael
Old 07-24-2013, 06:23 AM   #12
bluex
bluex's Avatar
i wanted to swap mine for the smaller ones too. It rides much better now after the flip. Since your planning a flip too, just leave them you wont regret it...
bluex is offline   Reply With Quote
Old 07-24-2013, 09:36 AM   #13
manimal
manimal's Avatar
Mine actually rides VERY nice.
-Lance
Old 07-24-2013, 11:15 AM   #14
Straight six
Yea the ride sucks now hopefully when I put the 4 leaf it will be much smoother ride. As for the front suspension is it basically the same 1/2 and 3/4 ton I heard just the brakes are bigger but everything else is the same
Old 07-24-2013, 11:19 AM   #15
Keith Seymore
Keith Seymore's Avatar
You can remove leafs from your existing spring packs. No rivet messing required.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-24-2013, 04:57 PM   #16
Tom
driving is in my blood
Tom's Avatar
K
Exactly what I was thinking. Why mess around with new springs and moving shackles when there is a much easier option that will also soften the ride.
Old 07-24-2013, 05:17 PM   #17
Straight six
Will removing the s couple leafs lower the truck as well I was going with the 4 leaf because of price. my leafs on there now are shot thinking of replacing them
Old 07-24-2013, 05:18 PM   #18
manimal
manimal's Avatar
should. I still would NOT move the spring hangers no matter what.
-Lance
Old 07-24-2013, 05:28 PM   #19
Straight six
Would moving the hangers compromise any integrity or stability in the trucks driving the way it rides. I'm asking because if I move the hangers and put new 4 leaf pack I don't want any damage to my baby lol
Old 07-24-2013, 05:33 PM   #20
manimal
manimal's Avatar
The longer 56" springs,with less leafs will have a softer ride than the std 52" springs. I would just remove every other spring(total of 3 at at first) and see how she rides then.
-Lance
Old 07-25-2013, 07:14 AM   #21
Keith Seymore
No - no compromise in moving the hangers.
Just replace the rivets that you cut loose with grade 8 bolts.
K
1979-1986
1986 - 2019
Old 07-25-2013, 01:01 PM   #22
Straight six
So when I put the 4 leaf pack on will it lower the truck in back. And if so won't I have to do the front at the same time. Hoping it doesn't lower to much
Old 07-25-2013, 02:05 PM   #23
Stepside Man
Stepside Man's Avatar
The amount of lowering will only be the thickness of the leafs you are removing. If you do every other one as directed you should not see anything significant because the curve in the main leaf has not changed. I would go with removing the leafs and not moving the hangers. Dont forget new bushings in all your holes while you have it apart.
1977 K10 6ft Stepside L6
1978 C10 8ft Stepside 400
1980 C10 8ft Widebox with Uncle L6
1986 K35 Not a dually 350; 79 K20 Stripped
1973 and 1976 Chevy Truck Trailers
1995 Impala SS LT1
Stepside Man is offline   Reply With Quote
Old 07-27-2013, 07:04 PM   #24
Axle
Axle's Avatar
I will add, if you have the extra heavy duty front coil springs (1050 lb/in I believe), its going to feel unbalanced with the now soft springs in the rear and the "firm" springs up front.
Alex.
Axle is offline   Reply With Quote
Old 07-27-2013, 09:15 PM   #25
LONGHAIR
Sure it will. With less support of the curvature of the leaves below it, the main leaf will flatten out, causing more drop.
It can also increase axle wrap and lowering the load capacity too. You just have to decide which of these factors matters....and how much.
