07-23-2013, 04:22 PM | #1 |
Under Dash A/C unit
Has anyone put an Under Dash A/C unit into one of our trucks? I see pics all the time of the complete systems, but never the under dash system. I would like to keep my original heater setup and just add A/C under the dash. It seems less intrusive to my trucks interior and I get to keep my glove box size intact too!
I would like to see some of the under Dash systems that have been used and possibly the data for them as well… or just the info so I can look the systems up. THX.
People who make excuses didn't want to do it in the first place! http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
07-23-2013, 09:29 PM | #2 |
Re: Under Dash A/C unit
My 64 motorhome has a underdash ac but my shifter hits it if your not carful, I was debating weather to pull it out or keep it seams how I'm in washington and dont really need it.
1966 C-10 longbed - Airide,350,3speed 1964 C-30 Camper - 327,4speed |
07-24-2013, 02:11 AM | #3 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-24-2013, 09:01 AM | #4 | |
My dad lives in Walla Walla and through his boasting about the weather I can see why you wouldn't need it... Now in Nebraska...
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
07-24-2013, 10:21 AM | #5 |
I'm in the process of installing a Vintage Air under dash AC/heat/defrost unit right now. The same unit is available without heat, but my truck doesn't have factory heat anyway. I'll post some pictures after I get it installed, which should be this weekend.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
07-24-2013, 11:23 AM | #6 |
07-24-2013, 08:44 PM | #7 |
I will be adding an under the dash style next year for that vintage look. Go here:http://www.oldairproducts.com/catalo..._38000000.html
I plan to use the 300 series as I like the ports.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
07-24-2013, 09:28 PM | #8 |
First, thx for the interest and the replies.
My concern; is that there is so little dash material to mount such a large unit to. It would seem to want to twist the dash material due to the load and the road roughness. Please, if you can take some pictures while your installing and after, I think we are all interested! Posted via Mobile Device
07-24-2013, 11:29 PM | #9 |
The one I just picked up had one. The guy removed it when taking out the wiring under the dash. Now I get to try to figure out ow to re-install it. It's an Allegro Mark IV. I don't have any experience with them, but it is something I would be interested in re-installing.
07-25-2013, 07:20 PM | #10 |
put one in my 63. it works great, no problems, the weight of the unit isn't all that much for the dash to handle. the brackets along with the stiffness of the hoses supports it quite well. get ready cause it will cool your truck cab for sure.
07-26-2013, 12:59 PM | #11 |
Hx--ck these out, the smallest i have found 16" L--4" H--12" D--Queencitycomponets.com or better pics at charlotterod.com
1961 chevy K10 my build is------------61K10 build |
07-26-2013, 01:14 PM | #12 |
Is there a link to an install of one if these on the site?
Posted via Mobile Device |
07-26-2013, 02:17 PM | #13 |
would be the same as any A/C, minus the heater lines.
07-26-2013, 02:24 PM | #14 |
Odd thing is the model I have has a heater symbol and knob on it also. Going to take some serious research before I put it in.
07-27-2013, 01:19 PM | #15 |
is there heater hose nipples on the ac unit?
07-27-2013, 01:35 PM | #16 |
I will have to look when I get home. I know there are two hose connections on the rear. I wasn't sure if it was meant for the heater core or compressor.
07-27-2013, 04:33 PM | #17 |
Try this on ebay. Everything goes up under the dash and then the vents run along under the dash lip. http://www.ebay.com/itm/160855632814...84.m1438.l2649
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
07-28-2013, 12:51 AM | #18 |
Rollin' Old Skool
A guy on Facebook mentioned having one, so I asked if he could post a pic. He said the nameplate reads "VEEP II"
07-28-2013, 01:24 PM | #19 |
Here is the unit I have.
07-28-2013, 01:37 PM | #20 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-28-2013, 01:40 PM | #21 |
07-28-2013, 01:42 PM | #22 |
07-29-2013, 11:44 AM | #23 |
I got my Vintage Air under dash unit mounted this weekend. The dash is still torn apart for wiring, but the defroster lines are and mounting is all hooked up.
It mounts to two bolts on the lip of the dash and two support straps at the back which I hooked up to existing bolts on the firewall. The dash did not deflect at all under the weight of the unit (which isn't too heavy anyway). They have smaller units, but since I live in Las Vegas and it's already hit 117 this year, I got the larger unit. My truck doesn't have any heater either, so I got one with heat as well. It does sometimes get chilly here during the winter. The best part is that while the evaporator is a generic unit, all the underhood parts are specific to 60-66 trucks from the same company.
07-29-2013, 12:05 PM | #24 |
Hey great thanks for the the links!!!
07-29-2013, 12:19 PM | #25 |
That unit looks great. I'm glad I found this link. Looks like I need to check into these more. Would be great to have A/C in the old truck. I might be missing everything for it other than the under dash unit.
HX, have you looked on EBAY also? I saw some Vintage Air kits on there. That's probably where I will have to buy my parts. |
