Old 07-23-2013, 07:54 PM   #1
Jfarns03
Jfarns03's Avatar
Unhappy 4L60E is acting up
Hey guys I've been tinkering with my transmission cooling lines on my 4L60E and the bolts(?) that were taken off before wont seem to fit! I've been messing around with it for the longest time. Are these none reusable? Also could you tell me which is the inlet and outlet? Thanks!
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 07-23-2013, 08:50 PM   #2
mmiddle
mmiddle's Avatar
Re: 4L60E is acting up
What bolts?
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-23-2013, 08:54 PM   #3
Jfarns03
Jfarns03's Avatar
On the passenger side of the transmission there are two holes for the Inlet and outlet for the trans cooler/radiator. I'm using the original piece that screws in over the factory pipe and it won't fit
Old 07-23-2013, 09:00 PM   #4
mmiddle
mmiddle's Avatar
Top is return, Bottom is supply.
The fittings are 1/4 STRAIGHT thread.
Russell and a few others make AN fittings for these.
Mark
Jesus is the Way!
Old 07-23-2013, 09:03 PM   #5
mmiddle
mmiddle's Avatar
I'm not completely sure what you are needing. The factory fittings retain the lines with a spring clip.
Maybe the treads on your fittings are gubbered up a little.
Mark
Jesus is the Way!
Old 07-25-2013, 10:58 AM   #6
Jfarns03
Jfarns03's Avatar
Yes that's what I'm talking about! I'm going to tinker with them today
