gears....?
i havnt posted in a while, been super busy with work and my truck hasnt broke on me, sunday i had to replace the universal joints (again!!)...my truck is a 84 k10 with 4-6 inches of lift...i put 4-6 because im not really sure which one it is im pretty sure they sent me a 6 but i ordered a 4, anyhow, i go through u-joints pretty often, I've 3 or 4 of them in 3 years time, not too bad i dont think at 8 bucks a piece or so, kinda getting off track here a bit, but with my lift im running 35's and got a th350 trans with a older 350 (about 150-250 thousand miles, not sure how many times its flipped but the previous owner said it was original) its pretty tired any how but running good, this thing is a slug, but i like it, someday i want to put a 700 in it due to mileage, but for the mean time im looking to swap gears, looking into 410's i just drive back and fourth to work, but like to play as well, just looking for some advice, ive had this truck for a few years and enjoy it, im just poking the bush really
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Re: gears....?
what gears are you packin now?
"DON'T TOUCH THE TRIM!!"-Early Kyler |
Re: gears....?
oh crap, i totally forgot to mention that...right now im running 3.08's....super slow take off...got so caught up in everything else i totally forgot the main reason i was posting!!!
Re: gears....?
i would put some 3.73s in it and double check your driveline angle since you are burning up u joints
#5 | |
Re: gears....?
this is the second set of axles thats been under my truck, the stock ones where 3.08's as well, so when i put the second ones under there and they turned out to be 3.08's as well i was freakin pis**d!!! the guy said they where 3.73's...so mad
Re: gears....?
but the newer axles where alot nicer looking anyways haha
Re: gears....?
Are your u joints greasable? Most of my lifted trucks have grease nipples in the joints & I have over 50,000 miles on the 86 since I got it without changing them.This is 4" lift.Do like meat wagon suggested & put in 3:73s or even 4:10s....
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Re: gears....?
ok this is the best way i have found to figure gears go find a gear calc online and put in the trans tire and tcase info and play with it. you will want depending on your motor around a 2200cruse speed for the motor. your cruse speed should be in the power band that way your not shifting all the time and not luging it down either
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
