Old 07-02-2003, 08:25 AM   #1
adkphoto
Starter Shims
Anybody know the "Proper" amount to shim a starter?
I've got a new standard size starter on my 350 Auto. Too much noise when the starter engages, so I suspect it's not shimmed right.
David
1972 Chevy Cheyenne Super LWB
Chevy Red/White with rally wheels.
Not-so-Stock 350, A/T, A/C, tilt.
Vroom, Vroom....
David Colbert dcolbert@twcny.rr.com
Work hard, play harder!
adkphoto is offline   Reply With Quote
Old 07-02-2003, 08:50 AM   #2
crazy longhorn
Fabricate till you "puke"
If you slide a 1/8" checker rod(pc welding rod will do), between the OD of the flex plate, & the arma ture shaft you can shim accordingly. If the meaure is too tight, you need to use the shims under both bolts......if its too loose, you need to cut the shims in half, & shim the outer bolt only. just use the 1/8" rod as a feeler guage(not loose, but not tight). Many of the reman starters come with this checker rod. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-02-2003, 01:33 PM   #3
adkphoto
Hmmm. I've never seen or heard of a checker rod before. Sounds like a good idea though. I wonder if I can use a #1 phillips driver instead.
Is the procedure the same for starters with offset bolt patterns?
David
Vroom, Vroom....
Old 07-02-2003, 01:39 PM   #4
Alex Hayley
Yes, the procedure is the same for the offset pattern. If the screwdriver is 1/8" in diameter. You could also use a 1/8" diameter drill bit.
Alex Hayley is offline   Reply With Quote
Old 07-07-2003, 08:58 AM   #5
adkphoto
Drill bit idea worked good.
I took out the two thin shims that I had installed and have a clearance of about 5/32". Must have some wear on the fly wheel. Not surprising considering its age.
Starter seems a little quieter and seems to have more torque. Amazing what a difference a 1/16th of an inch can make. Thanks for your help guys!
David
Vroom, Vroom....
