Old 07-24-2013, 02:47 PM   #1
Formanbob
A arms, Can’t make up my mind.
So I can’t decide how I should rebuild the front suspension on my 1964 c10.
I bought a Porterbuilt stage 2 deluxe kit for the rear and the stage 1 kit for the front. When I tore the front apart I found that most if all the joints and or bussing were needing replaced.
I could just buy one of the eBay rebuild kits for around $250 or I could order a set up tubular a arms from Porterbuilt.
The only problem with the Porterbuilt option is just that so many options.
I can get them moved forward
I can get them shortened
I can get the moved forward and shortened.
I would love to lay frame don’t get me wrong but I don’t want to lose and bed space so I am happy with what I will get out of my stage 2 deluxe rear kit. But after talking with Porterbuilt is sound like I will not be able to use the moved forward and shortened arms if I ever swap the front k-member out for a drop member.
But I don’t know if I would ever need a drop member.
I feel like I should just put the time into sand blasting the OE front a arms and rebuild them but I want the front stance to match the rear stance as well. Not to mention I don’t have the $$$ to buy the Porterbuilt A arms anyway.
Sorry for the rant.
Formanbob is offline   Reply With Quote
Old 07-24-2013, 07:14 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: A arms, Can’t make up my mind.
Save up the money and buy the PB standard a-arms,...
Keith
Convert to disc brakes.
Old 07-24-2013, 07:18 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've been thinking about doing this. Mine are alright, but its time for an alignment and I have a feeling the hard miles on a variety of tire combos and no real alignment has probably shortened their lives. I've considering rebuilding or doing some fab work to mine, but its really really hard to argue with the quality and r+d that PB has done,.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-24-2013, 07:29 PM   #4
davidfre21
Ill probably get Michigan metal arms. I think they look slicker than PB arms.
davidfre21 is offline   Reply With Quote
Old 07-24-2013, 09:58 PM   #5
Formanbob
I did not see anything for a 64, plus I'm not to sure that flat plate is going to be as strong as the pb tubular arms
Old 07-24-2013, 10:01 PM   #6
Formanbob
That's what I feel I should do, now you said standard arms, do you say that for a reason, like not getting them narrowed, or moved forward?
Old 07-24-2013, 10:08 PM   #7
Formanbob
Do you plan on getting them moved forward or shortened, and do plan on getting a drop member?
Old 07-25-2013, 02:11 AM   #8
andrewmp6
Shorten is good if your gonna like a 22 or bigger and need room.Moving them forward is good for any lowered truck really.Forward centers the wheel in the wheel opening giving you more room by the firewall.As far as Michigan metal works his stuff is strong and built to take a beating.Hes like the Porterbuilt of the mini truck world.
andrewmp6 is offline   Reply With Quote
Old 07-25-2013, 06:01 AM   #9
lolife99
lolife99's Avatar
IF you ever plan on getting a DROPMEMBER,... you can't use the Forward Series arms.
Narrowed is up to you and your wheel choice.
Keith
Old 07-25-2013, 06:06 AM   #10
lolife99
lolife99's Avatar
I think he is alot bigger than the mini truck world.
Michigan Metal Works makes more a-arms for more vehicles than ANY other company I know.
Not limited to any certain make.
From 1/2-ton to 1-ton trucks.
More specialized than any other company, when it comes to building bagged truck a-arms, 4-links, watts links and custum fabricated spindles, for many differnt model trucks.
His company is huge!
Several years ago I remember him saying he went though $40,000 worth of plate steel that year.
He is much BIGGER than that now.
I would never doubt any product that comes out of his shop.
Keith
Old 07-25-2013, 07:14 AM   #11
andrewmp6
Yeah he started out in the mini truck world but branched out to pretty much any truck made almost now.
Old 07-25-2013, 08:20 AM   #12
Formanbob
So I plan on staying with stock rims or maybe some Nissan 18-20" so could I stick with stock length?
Old 07-25-2013, 08:21 AM   #13
Formanbob
So do MM make arms for the 64?
Old 07-25-2013, 09:09 AM   #14
andrewmp6
His site just shows 73-87 but since the 60-72 truck is close talk to him and see what he can do.
Old 07-25-2013, 12:19 PM   #15
lolife99
lolife99's Avatar
Yes.
Because you will probably need spacers also.
Keith
Old 07-25-2013, 12:20 PM   #16
lolife99
lolife99's Avatar
Sure.
The balljoints would be the only difference.
I'm sure you could order them with or without the 63-70 ball joints.
(or whatever year spindle you are using)
Same for the Porterbuilt arms.
Keith
Old 07-25-2013, 01:29 PM   #17
Formanbob
Yes.
Old 07-25-2013, 01:49 PM   #18
Formanbob
Sure.
Old 07-25-2013, 02:36 PM   #19
king-918
king-918's Avatar
My advise is buy what you want and if you cannot afford it save because you will regret it later
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 07-25-2013, 04:33 PM   #20
SCOTI
SCOTI's Avatar
Sure.
I'm sure you could order them with or without the 63-70 ball joints.(or whatever year spindle you are using)
MMW comes w/o BJ's (you install your own so you could do whichever year needed 63-70/71-87). The alternative he offers are the joints that offer more range when laying out on big diameter wheels w/o binding (can't remember what they're called).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-25-2013, 04:58 PM   #21
fishingjred73
fishingjred73's Avatar
Jeebus Joint
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 07-25-2013, 06:13 PM   #22
SCOTI
SCOTI's Avatar
Originally Posted by fishingjred73 View Post
Jeebus Joint
Yep... That's them. Now I don't have to look it up (would have festered tonight ). Thanks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
