what size bolt???
This is my first post kinda new at this, i was needing some help on what size bolt for mounting the motor to the motor brackets on frame.
Re: what size bolt???
I think they are 7/16.
![]() Join Date: Aug 2008
I recently helped a friend install an engine in his 68. He had pulled the old engine and was using the same bolts to install the new one. It had been "reatores some time before and he couldnt get the engine mounts in engine or the frame to stand bolts. Turns out they were using 7/16" bolts in 7/16" holes. I sent him to Tractor Supply for grade 8 3/8" bolts and we had it in in 30 minutes.
Posted via Mobile Device |
Still plays with trucks
Yes, they are 7/16-NC bolts with lock washers and large flat washers.
Can't remember exactly how long they are but it is at least 1" long but not longer than 1-1/2".
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
appreciate the help i just dropped transmission off to get new seals so we are going to try to put in this weekend, lets see how it goes
