Frame Reinforcement
I had to cut some of the frame to fit the headers i chose to put on the engine. I also had to cut a hole in the crossmember to fit em. I'm wondering how i can reinforce the frame without having to weld. I want to get some strips of heavy duty stainless and bolt them with grade 8 bolts. I want to get strips and bolt them above and below the hole in the crossmember and one on the frame where to deepest cut is..... any other ideas. i want to stay away from welding because i dont have the means or a way to do it. I'm hoping its possible to do without having to weld
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
![]() Join Date: Aug 2012
Re: Frame Reinforcement
Would have been easier to buy a set of headers that work. That's a mess under there for sure. Good luck sounds like you have a plan.
Posted via Mobile Device |
i searched and searched and supposedly these headers were supposed to fit without major modifaction.... now i wonder what major modifaction actually means
20' Daredevil (Ret)
![]() Join Date: May 2003
I'd bite the bullet and pay someone to properly repair both the frame and the crossmember, and that means welding. Not to give you a hard time but I wouldn't have cut structural pieces if I couldn't weld... just my 2 cents.
Did you move the engine stands to the v8 position? It looks like your problems may be because headers are hitting due to engine being in 6 cylinder position. If headers are correct for truck the cutting you have done should not have been needed.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#6 | |
Still plays with trucks
What application are those headers for?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Interested. Keep us updated.
1969 Chevy c20(Miss Hackjob) |
Yikes, I hope those headers are absolutely badass. If you get the strips of stainless steel to reinforce the cuts in the frame, won't they cover up the notches you made for the headers and (thus) render your modifications null?
You may not have the means to do it now, but welding may be a useful skill to learn when building and restoring old vehicles. I too have no real clue about welding, but as soon as I struck my first arc I was hooked. Not trying to be pushy against your situation, everyone has their own circumstances that limit what can be done (money or time usually being the biggest culprits), but down the line it may be something to consider. Main piece of advice I have to offer: It's easier to find out why something doesn't fit, than to make permanent modifications to make it work. |
I love welding but can't do it worth crap lol. There not pretty but there solid
If your welding looks bad then practice would help. But in the meantime just pay a pro to fix the mess.After all it's only money.
I don't think it looks that bad. Personally, I would leave it the way it is.
![]() Join Date: Jun 2013
They may not be as solid as you'd like to believe. I have just about 60 years' experience in all methods of welding and I do not trust anyone's welding if it doesn't look good, or at least very neat.
#13 | |
Your idea of bolting on strips of stainless has no engineering merit at all. You will wind up with a perforated frame you can throw away. |
#14 | |
![]() Join Date: Jul 2013
As an R&D guy for more than 20 years.... Rough edges are a sure-fire place for cracks to form. It may or may not ever be a problem, but if you head-on the truck that engine is likely to visit you inside the cab.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#15 |
Another consideration is what will the next owner think of your work. I've redone quite a few trucks and motorcycles, not even one with the thought of selling it. But invariably someone sees it, likes it, and makes me an offer I can't walk away from, because I know I can do this again and probably better.
I didn't even think about ragged edges being stress points, but then I've never left a ragged edge. |
#16 |
To be honest, I it were my truck or one I just bought. I would pull the motor, cleanly dress the cuts and weld in 3/16 plate. And when I sat weld, I don't mean with a flux-core wire welder. These need at the very lest solid core MIG wire or best Tig welded. You have created very critical stress points.
I know it may sound like we are being harsh here. Don't take us wrong cutting or notching the frame and cross members is not a big deal, many of us do it for one reason or another. But, What has us freaked out is the roughness of the cuts and the idea of bolting patch plates around the holes. I know this is apples to oranges... but aircraft have fallen out of the sky due to small scratches in a wing spar. Even tooling marks in a machines surface can create a stress point.
#17 |
I might get scolded for this, but I personally would not drive or ride in a vehicle with a frame that looked like that. Please get it fixed, no set of headers are worth the mess that could get you in.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
