Old 07-02-2003, 11:19 AM   #1
case_bt
case_bt's Avatar
Voltage Regulator problem I think
Is there away that a electrical system can put out to may volts?
I seem to be having a problem when my truck starts the starter make a high pick noise then it starts fine before I started it I checked the voltage on the battery anf it had 18.5 volts (which is way to high) on it and after I started it is was 19.4 what does this mean is my alternator shot or is it my voltage regulator It looks very old.
Common sense tells me it is the regulator because the system is still charging.
case_bt is offline   Reply With Quote
Old 07-02-2003, 11:38 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Voltage regulator. You may want to disconnect the connector on your alternator until you replace the regulator. Too much juice to the battery may cause it to explode
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-02-2003, 01:35 PM   #3
barn9
Half a bubble off!
barn9's Avatar
Sounds like a good opportunity to switch to an internally regulated alternator and do away with an archaic voltage regulator to me. You'll be glad you did if you change over.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-02-2003, 02:57 PM   #4
Custom 68
Custom 68's Avatar
first I dont think you can have 18.5 volts on the battery if it is not running. I think you better check you volt meter before you go any further.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-02-2003, 05:19 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have to agree with Custom68....you'd be blowing fuses and little lights at almost 20 volts.
However, if in fact you are getting that kind of power out of it all, I'd swap over to the intenral set up.
Old 07-05-2003, 11:37 AM   #6
case_bt
case_bt's Avatar
it was a bad meter used my good one from work and it was normal I my starter must be on its last leg
Old 07-05-2003, 01:42 PM   #7
jef5150
Inline 69
jef5150's Avatar
"amperage",,,,,not volts..if your fuse blows w/20 volts going thru it,you"ve got some "F'd-up wiring....LONGHORN=just pokin fun at ya,i know you know your sh*t!!!!!!!
jef5150 is offline   Reply With Quote
