Old 07-25-2013, 10:23 PM   #1
AJLChase
AJLChase's Avatar
Foam used to center molding clips?
I have a piece of chrome molding that has come off and I purchased the necessary clips, as they were worn and the reason why the molding wouldn't stay. I noticed there was a foam type molding that helped keep the clips centered into the punched out hole. What was used or what would be good enough to use in order to keep the clips centered?
AJLChase is offline   Reply With Quote
Old 07-26-2013, 05:33 AM   #2
JimKshortstep4x4
Re: Foam used to center molding clips?
The clips are self centering and the foam is used to seal the holes. I use 3M strip caulk for sealing, if the foam is missing (commonly referred to as dum dum).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
